S60 strange
S60 strange
I just purchased a Strange S60 and need to know what bushings to run in the upper bushings stock suspension.
No adjustable arms all stock.
Part numbers would be great.
Jharken
Jharken
I would assume they could just use a stock rubber/steel replacement bushing if that's what you want, but if you're running a S-60 rear I would assume you also have some power to put through it. A fully stock rear suspension is pretty sloppy even with all new rubber bushings. Maybe consider the black urethane type?
