differential decoding help
What year is your car? If you look on the passenger side axle tube, probably facing towards the rear (but also possibly facing forward), you might find a two-letter code or a letter-number code. That code will tell you the gear ratio in your differential (if someone hasn't changed it) as well as if it is a posi or open rear end. If you can find that code, post it along with the year and model of your Olds and someone here can tell you what that code means.
Randy C.
Randy C.
On my 74 the code faces toward the front of the car and is on the inboard side (close to diff) of the pass side axle tube. You may need to scrape around if it's greasy to find it.
Like Randy said, we'd be happy to decode it for you.
i got a few codes from the diff and the axle tube right where you said it would be. the numbers on the diff are 1234496, this was found on the oil cover. and 1235197 this was found on the passenger side of the diff on the side sort of of the pumpkin. the one on the axle tube was this SA 021 1, and it could have possibly been 0 SA 021 1 idk anything aobut these numbers or what they are supposed to look like but thats what was there. if you can get anything out of these that would be great. thanks alot its an open diff and i know that because i dont have a tag on my diff, but when i do burnouts only my right rear spins
i need a posi haha
i need a posi haha
LIMEGREEN71
Drivetrain/Differentials
Feb 22, 2010 03:45 AM
