1963 F85 constant velocity repair kit
Any leads on where to find a 1963 F85 constant velocity repair kit (small set of parts that goes in the double ujoint assembly). Fusick and Northwestern Auto parts did not have them.
Maybe Kanter's has it:
http://www.kanter.com/eCatalog/00052.htm
or check a local driveline shop that builds driveshafts.
www.rockauto.com is another possibility.
These are difficult to find. I am not aware of a readily available source. As Joe noted above, a driveshaft shop might be able to find something that works. N.O.S. parts often show up on ebay, so create an automated search for them. Note that 61-63 F-85 and Buick Skylark driveshafts use the same parts.
costpenn
Sep 28, 2014 06:43 AM
