69 cutlass rear end question swap?
Old Aug 15, 2011 | 08:17 AM
Beeks69's Avatar
I have a 69 cutlass with a 350 2 barrel automatic 2 speed and 2.56 gears a guy offered me a 3.42 anti-spin rear end out of a 72 cutlass been sitting 10 years in a field he wants 300 bucks for it any thoughts of is it a deal does it pay for my application?
Old Aug 15, 2011 | 10:14 AM
Cheap price, open it up and have a look first. Confirm the ratio, it will wake up your acceleration a bit, a 3 or 4 speed auto would be a big help, but it depends on your usage.
Old Aug 15, 2011 | 11:11 AM
Beeks69's Avatar
The guy I am buying it from bought the car brand new and is parting it out now and scraping the rest so it is a 3.42 anti-spin rear end cause he ordered it that way so didn't know if it is worth it or not.
Old Aug 15, 2011 | 11:19 AM
Rickman48's Avatar
I'd say go for it, and see if he's gonna sell the trans and crossmember, too!
Total bolt-in!
Engine would be an improvement, too - higher compression!!
Old Aug 15, 2011 | 10:20 PM
Compression was lower in '72, 8.5:1. If in good condition it is worth double what he is asking.
Old Aug 16, 2011 | 01:09 AM
svnt442's Avatar
If you get the rear you're going to need to do something with the driveshaft one way or another. The 72 yoke is a different length than the 69 yoke so the length of the driveshaft has to change the same amount.
Old Aug 16, 2011 | 04:20 AM
Beeks69's Avatar
The rear is in good shape I bought it last night. Sounds like I am getting his 455 that is in it and the turbo 400 car ran and drove fine til the day he parked it said there is a shift kit in the tranny. Sounds like my 350 is going to get swapped someday.
Old Aug 16, 2011 | 05:32 AM
507OLDS's Avatar
Get the driveshaft too.The 71-72 8.5" 10-bolts use a shorter driveshaft because those rears have a longer pinion snout.Remove the cover,drain the fluid,and see what you have.I would highly suggest putting new bearings & seals in the whole thing,while it is out of the car.
Old Aug 16, 2011 | 05:40 AM
Beeks69's Avatar
Yeah I got the driveshaft last night. When I have it ready to put in will my driveshaft work or what do I need to do to use it until I do the full swap?
Old Aug 16, 2011 | 06:14 AM
507OLDS's Avatar
Even your existing driveshaft,for the TH350 trans,will be too long.You would need to take about 3/4" off of it,for it to work with the 8.5" 10-bolt.
Old Aug 16, 2011 | 06:17 AM
Beeks69's Avatar
Rite now I have the 2 speed jetaway so I can not just put this rear end in for now? Is what your saying? That sucks if so I was hoping to see what kind of difference the 3.42 gears would make
Old Aug 16, 2011 | 06:21 AM
507OLDS's Avatar
NO.You will need a shorter shaft.
Old Aug 16, 2011 | 06:23 AM
Beeks69's Avatar
Can I use the driveshaft I got with it from the 400? or is that not compatible? I appreciate the help I don't know much on this end
Old Aug 16, 2011 | 06:28 AM
507OLDS's Avatar
NO.It will be too short with your Jetaway.You can measure the 2 shafts,but I think the differences are too much.
Old Aug 16, 2011 | 06:29 AM
Beeks69's Avatar
That sucks! Sounds like I need to put the 400 in rite away
Old Aug 16, 2011 | 06:43 AM
507OLDS's Avatar
Maybe you could find someone parting a 71-72 Cutlass 2-dr,that you could get the driveshaft from.From what I remember,the 2-spd Jetaway,and the TH350 are the same length,so a typical 71-72 Cutlass 2-dr,with the Th350,would have the correct length shaft.They all came with the 8.5" rear,and the engine/trans placement was the same for 68-72.If I get a chance,I will measure one of mine,so you know what length of shaft is correct.
Old Aug 16, 2011 | 06:45 AM
Beeks69's Avatar
That would be great. I appreciate that very much!
Old Aug 26, 2011 | 04:41 AM
Beeks69's Avatar
I have my new rear installed. It made a pretty big difference going from 2.56 to 3.42 next step is to get rid of the jet away for a th350 thanks to everyone for there help.
350TurBRO
Sep 12, 2014 11:52 AM
Outlaw88
Drivetrain/Differentials
Dec 26, 2013 06:04 PM
4Door67
Nov 8, 2013 09:35 AM
Doomah
Aug 6, 2013 05:48 AM
olds cutlass
Apr 9, 2009 05:44 PM
