Lower control arms - rear
Old Jan 9, 2011 | 05:49 PM
1970442w30post's Avatar
Looking things over today......anybody got any ideas what these control arms are??? I assume they are not stock, or did somebody weld those triangles on????
Old Jan 9, 2011 | 05:54 PM
BIGJERR's Avatar
I bleed Oldsmobile
WTH???????
Somebody got happy with the welder!.................Some sort of suspension stops?
Old Jan 9, 2011 | 07:01 PM
gearheads78's Avatar
car guy
I have seen something similar to that before on a car that was raced in the 70's. Like Jerr side some sort of travel limiter.
Old Jan 10, 2011 | 05:30 AM
monzaz's Avatar
control arms
MAn that is gonna make some noise when it does limit...lol.
IS it supose to hit the frame? cause that is right in front of where the rubber bumper goes for frame bottom out. I do not know what that deal is.
It is either old school or New brain fart.... lol
Old Jan 10, 2011 | 05:33 AM
I have never noticed any issues with anything binding or thumping.....should I leave them or cut them off? I am pulling the rear anyways, so cutting them and cleaning will not be an issue..
monzaz's Avatar
rubbing
Looks like it is rubbing the brake line too between the frame and those triangles?? I do not think the control arms stand a chance if a lot of force was applied down on them as they would buckle if not boxed etc. ???
Old Jan 10, 2011 | 05:42 AM
Old school!! I am taking the 4.66s out, so I don't believe I will be needing the reinforcments anymore...LOL
Old Jan 10, 2011 | 05:44 AM
There is a rubber cover over the parking brake lines, those have a little indentation from these add on triangles.
Old Jan 11, 2011 | 05:13 AM
507OLDS's Avatar
Those arms don't looked boxed,are they? Either way,get those outta there.If they are boxed,maybe you can trim those extensions off & reuse,as long as they aren't damaged.If they are not boxed,just remove them,and put the correct ones in there.
Old Jan 11, 2011 | 05:32 AM
They are not boxed.....What should this car have? Boxed lowers with sway bar? without sway bar?
What does the rear sway bar do, help body roll?
Old Jan 11, 2011 | 06:07 AM
507OLDS's Avatar
The car originally came with boxed lower control arms & a sway bar.Yes,the sway bar helps reduce body roll,and it also helps keep the car level,side to side,when launching,but back then,people were thinking a little different.
crazy'boutOlds
Oct 4, 2011 05:45 PM
66-3X2 442
Oct 4, 2011 09:13 AM
RAMBOW
Mar 16, 2011 03:56 PM
JSGD1966
Oct 5, 2010 08:26 PM
doc
Suspension & Handling
Jul 18, 2009 03:26 PM
