Need help identifying my rear end
Old Nov 30, 2023 | 10:18 AM
SRV8's Avatar
Hi I need help identifying my rear end. It is in a 1972 olds cutlass supreme convertible, Rocket 350 with TH-350, need to know which axle typ it is because want to install posi in it and which I should order
Old Nov 30, 2023 | 11:15 AM
That's the Oldsmobile version of the Corporate 8.5" ten bolt used under every Cutlass Olds built in 1971-72. Bolt-in axle shafts, so the bearings and seals are different, but otherwise identical to the Chevy 8.5" 10-bolt. "SA" is the 2.73:1 open axle.
Old Nov 30, 2023 | 11:34 AM
SRV8's Avatar
Ji Joe I
ask because of the housing here it looks different to other 8.5 axle GM and how many spline has it stock
thx for your help
Old Nov 30, 2023 | 03:05 PM
Don't worry about those "horns". Look at the side of the center section for two parallel ribs, the front sides of the center section for a cast in block "O" that is the identifier for an Olds version of the corporate 10 bolt rearend, and the top of the center section for a drilled boss where the brake junction block bolts on. I think the Buick version (that sometimes was used in the Cutlass line) has an A instead of an O, but is essentially the same.
Oh yeah, and that 407296 casting number is a dead giveaway.
Old Nov 30, 2023 | 03:21 PM
SRV8's Avatar
Hi does the axle have standard 28 or 30 splines
Old Nov 30, 2023 | 03:38 PM
Have you tried using both hands and a flashlight?
Old Nov 30, 2023 | 03:46 PM
...and, a mirror comes in handy. I'll grab a cookie on my way out....
Old Nov 30, 2023 | 04:30 PM
28 spline.
Old Dec 1, 2023 | 03:29 PM
Originally Posted by bangscreech4-4-2
have you tried using both hands and a flashlight? :d
Old Mar 2, 2025 | 06:22 AM
Ronw29's Avatar
Please help
Can anyone tell me what rearend this is? I know it’s a Oldsmobile but I don’t know what spline or anything. I want to change my gears. Thanks.
Old Mar 2, 2025 | 06:33 AM
You have a ten-bolt, 8.5" ring gear "corporate" rear axle, as seen in all 1971-72 Cutlii. Other than the bolt-in axle shafts (as opposed to C-clips), the internal parts all interchange with those for a common ten bolt Chebby axle. Parts pretty much grow on trees. Yes, you can run the normal Chevy internals without the C-clips.
Old Mar 2, 2025 | 10:16 PM
monzaz's Avatar
1971 -1972 Chevy A body ARE 8.2 not 8.5 so you should specify that the (camaro are 8.5) 1973 -1988 chevy a x b c body Truck 1973-4 ish -1987 with 10 bolt round cover like the 8.5 are inter-changeable. Just trying to keep things clear for everyone.
Jim
JD
Old Jul 31, 2025 | 08:20 AM
Ronw29's Avatar
Help
I have a 72 type ‘O’ rearend with 28 spline axles and I’m wondering a couple different things 1) do I use chebby axles or the 68-70 Oldsmobile axles??? I know those splines are cut at 30 degrees. 2) can the 68-70 bop 8.2 gears be used in the 72 type’O’ axle??
Old Jul 31, 2025 | 08:29 AM
You sure about that? IIRC, last year for production of Type O was 1970.
Old Jul 31, 2025 | 04:07 PM
As said above, you do not have a 1972 O-Type rearend.
1) 8.5" 10 bolt, bolt-in style axles.
2) No.
Old Jul 31, 2025 | 04:21 PM
Ronw29's Avatar
My rearend housing has a ‘O’ on it?? I only wanted it get 1/2 studs but I couldn’t use original axles because too many access holes making it impossible to drill out 7/16 to 1/2. Don’t want to change the whole rearend. One more question for you guys while I have you, has anyone put wilwood brakes on this type of axle before? I can’t find a Direct fit, so I’m wondering if there’s another way to get them to fit?
Old Jul 31, 2025 | 05:05 PM
If you are referring to the block "O" on the side of the center section, that identifies it as a 1971-1972 Oldsmobile version of the 8.5" 10 bolt rearend. It does not signify an O-Type, which has a 12 bolt cover.
Below is a picture of my 1971 8.5" 10 bolt showing the "O" and the casting number, which is the best method of identifying the rearend.
Old Jul 31, 2025 | 05:43 PM
Ronw29's Avatar
Yup that’s looks the same… man Oldsmobile really made things difficult. I guess I’ll just use the stock axles and wheel studs for now and try to figure out how to make the wilwood brakes work on the rearend. I put wilwood 6 pistons up front and the hubs came with 1/2 studs which I thought was great and wanted to match them up but I guess it wasn’t meant to be. The rear wilwood I have are for the bop rearend which uses a bigger bearing and I’m hoping I can just use the original bearing retainer plate to get them to work instead of using wilwoods retainer plate which is too big. There’s has to be a way because I see 71’s and 72’s all the time running them.🤷‍♂️
Old Jul 31, 2025 | 08:00 PM
There are multiple companies that make axle shafts (and other parts) for the 8.5” 10 bolt rearends since they were used on multiple GM division vehicles for over a decade, so you should be able to easily find whatever parts you need.
Olds68swede
Drivetrain/Differentials
Jan 11, 2022 01:52 PM
tkcutlass
24
Mar 27, 2021 07:42 PM
scottr2200
Jun 23, 2020 09:20 AM
Nasty455
20
May 5, 2012 04:07 PM
72CUTTY
Feb 11, 2012 07:13 PM
