65
Old Dec 2, 2021 | 05:22 PM
65-330's Avatar
65
Ok, so i have a 65 f-85, 330 rebuilt to stock before i bought it. I plan on adding intake, cam and lifters, roller timing chain. Right now I have opgi w-30 manifolds thats going in soon with 2.5 exhaust, going to install a rebuilt turbo 350 soon. Now, the rear end gears are 3.08, not posi. What do you think about adding 3.36 with a posi?
Old Dec 2, 2021 | 05:38 PM
2blu442's Avatar
I don't think the 3.36 is an option with Olds rear ends. But you could go 3.23 or a 3.55. The 3.23 is a good all around gear, but if you wanted it a little snappier the 3.55 might be worth considering.
Old Dec 5, 2021 | 08:42 AM
monzaz's Avatar
3.36 3.55 3.73 3.90 4.33 4.10 4.56 4.88 5.13 are all available in the after market of GM gear ratios are underlined. .
The deal with your differential is that a 3.08 carrier can only hold 2.93 3.08 3.23 ratios
The 3.36 -5.13 will be on the next series carrier up
SO do think about that.
Why would you not want to keep the 3.08 gears? They are great for all around driving and still can have some fun at the track.
You just need a posi and I would re bearing the rear. GOOD to go!
We have all the other 3.36 posi bearing etc... if you still want to go that route too.
Jim
JD Race
Old Dec 5, 2021 | 10:48 AM
65-330's Avatar
Yes. i'm going to keep the 3.08 and just add posi, thx for your write up! Where can I get a posi
for the 3.08,? Or how about the lock up? Rather go posi
Old Dec 5, 2021 | 12:33 PM
69CSHC's Avatar
Great engine, I assume the low compression 250 HP version ?
If so I had the same spec engine in my first car a 1967 Cutlass Holiday Coupe. It sold me on Olds for life, going on 35 years now.
Mine was 3 speed manual and 3.08 rear. Definitely made for quick acceleration back in the late 1980s. But if I were you and you are going into the rear anyway for limited slip purposes I would go with a more aggressive gear as well. Talking to car guys over the years that daily drove these type of cars back then you don't want to exceed 3.73 or it will likely drive you nuts on a non overdrive transmission.
You can ease off the gas pedal on an aggressive gear, but cant put the pedal trough the floor when asking for more ...
Old Dec 5, 2021 | 07:57 PM
65-330's Avatar
No, 10.25 compression with 4 barrel. Have not really driven it yet, I would not want 3.73. I would say 70% street other hwy. I'm going to keep the 3.08 and just add posi.
Old Dec 7, 2021 | 08:34 AM
monzaz's Avatar
Also think about what you think is cool. Acceleration or just plan burn outs. ...3.08 will not affect a burn out...the more freeway type gearing the more SMOKE in the burn out.
Gears are for making the car go from point A - B quicker...BUT remember too, traction is ALWAYS an issue on the street and your only going to get so much acceleration on the street from a DEAD stop.
We did a Monza with a small block and it is only a Summit Budget TABLE motor long block that was dropped upon delivery (valve cover muffed. ) Swap the vavle cover did the edelbrock performer intake 600 holley
350TH trans 200 stall left the 2.56 gears in the 7.5 and installed a posi ...We run that car everywhere and it is the most driven car in our house hold as it is just fun torquey driver with no worries ...does 1000 foot burn out and still drive 80 on the freeway...
Youngest daughter plays at the track with it in the JR Street... 14.50 1/4 mile and 9.50 1/8th ...this class can not go faster than the 9 sec mark in the 1/8th mile. Kids with out drivers license yet and a parent need to sit in passenger seat down the track..
She does JR Dragster too 7.90 1/8th 140# weight added to slow it down... these things really go... 85 mph
LOOK AT THE REAR SLICKS ON THE JR.! LOL 1.57 60 FOOT
Old Dec 7, 2021 | 08:37 AM
monzaz's Avatar
oops little too big...Sorry... :( Jim
Old Dec 7, 2021 | 08:56 AM
stan 65 cutlass's Avatar
double check those w30 exhaust manifolds, big block manifolds may not work for you
Old Dec 10, 2021 | 02:21 PM
65-330's Avatar
I got the opgi manifolds that bolt right up
Old Dec 11, 2021 | 08:32 AM
jcdynamic88's Avatar
i think you will find the 3.08/th350 combination quite responsive.
Old Dec 11, 2021 | 08:36 AM
65-330's Avatar
I'm sure it will be!
Old Dec 11, 2021 | 09:09 AM
Which "OPGI manifolds"? Real BBO W/Z manifolds will bolt to any Olds heads. They will not clear the starter, motor mounts, or other parts on an SBO when installed in the car. The aftermarket SBO manifolds that are claimed to be "W30-like" manifolds are the same size as any other SBO manifolds. The emphasis is on "claimed to be."
Old Dec 11, 2021 | 09:15 AM
65-330's Avatar
Thornton manifolds, drivers port is bigger than stock and no more cross pipe
Old Dec 13, 2021 | 02:00 PM
Gerald Nickels's Avatar
The new W-31 manifolds will work not the 442-W-30.
Old Dec 13, 2021 | 02:12 PM
Actually the OP has a 1965 330. His "W30" manifolds are actually the Thornton aftermarket SBO manifolds that are supposed to look like W/Z manifolds. Emphasis on "supposed to".
DaveD65
Feb 20, 2014 05:36 PM
65cutty
Mar 27, 2010 05:04 AM
65cutty
Drivetrain/Differentials
Mar 27, 2010 04:51 AM
frank50
Site Help
May 16, 2009 10:47 AM
65Delta88
May 21, 2008 07:04 AM
