Differential replacement 71 Cutlass
Old Jan 14, 2021 | 06:29 PM
Jhucks03's Avatar
I’m wanting to change to a posi differential in my 71 Cutlass.
Best I can tell it’s a corporate 10-bolt (bolt-in axles).
Can anyone provide part numbers for carriers and install kits? I’ll be keeping the 3.42s I swapped in quite a while back.
Old Jan 14, 2021 | 07:30 PM
If you have 3.42 gears, a factory 410408 limited slip differential should fit. That is the casting number for a factory 2.73-up limited slip differential.
Old Jan 15, 2021 | 06:22 AM
The original axle in every single 1971-72 Cutlass was a Corporate 8.5" ten bolt from the factory. All Chevy 8.5" ten bolt internal parts fit.
Jean
Aug 7, 2020 07:46 PM
Bobby455
Apr 26, 2020 04:57 PM
kjr442
May 26, 2014 07:31 AM
lsutigers93
Mar 24, 2014 10:21 AM
1BLACKHARLEY
Mar 12, 2007 12:31 PM
