Wow!
Wow!
Had some time today and wanted to i.d my rear end ratio. Spinning the right rear tire one revolution showed the driveline rotating approximately 1.5 revolutions....after scratching my head for a while i realized the remembered the rear tires are 18" as installed by the p.o. Looks like i have a 1.5 rear ratio....no wonder the performance is lacking lol. Car is a 1969 Cutlass and came with 2 spd trans and 350 2 bbl carb with a.c. currently has TH350 with shift kit and 2,300 rpm stall. Can you say gear change? Lol.
If only one tire was rotating, the driveshaft will only turn half as far.
Try turning the driveshaft with both wheels off the ground, so that they can both turn.
You've probably got about a 3.08 (or maybe a 2.93).
Never knew that, thanks. Car was born a 350 2bbl with a/c im thinking its a 2.56
Its really tough to determine a ratio by turning the shaft/wheels on an open rearend. LOL- I think it takes about three people to do it -- one for each wheel and one for the shaft - so theres no movement in the side gears? Removing the cover is really the only "foolproof" method to be positive!!! Even if the tube code is ID checked it could still be wrong due to someone changing the gearset??
Actually, it's pretty easy. Simply block one wheel so you are sure that only one is turning, then multiply the number by two. Also, since it it difficult to see the difference between, for example, 3.23 and 3.42 turns of the driveshaft, I rotate the tire ten times then divide the driveshaft turns by ten. It's very easy to see the difference between 32.3 and 34.2 turns.
Love this place --- learn sumptin every day!!!
monzaz
Mar 15, 2009 04:43 PM
