Will it hold?
Old Jun 25, 2013 | 06:14 PM
88olds350's Avatar
Unhappy Will it hold?
I have an 88 cutlass supreme, I pulled the 307 and 200r4 tranny and put in a mild build 350 with a turbo 350 tranny with a blue plate? shift kit. I plan to run the stock rear diff and drive shaft just to break in the motor. Will the Diff and drive shaft hold up to the power if i were to jump on it? The motor is fresh bored 30 over, dish pistons, one step up from a stock cam, w-31 #5 heads, edel performer intake with a 650 cfm carb.
Old Jun 26, 2013 | 08:18 AM
Originally Posted by 88olds350
I I plan to run the stock rear diff and drive shaft just to break in the motor. Will the Diff and drive shaft hold up to the power if i were to jump on it?
Yeah, you'll break the 200-4R first.
The valve body plate isn't the problem on that trans. It's the internal hard parts that need to be upgraded.
Old Jun 26, 2013 | 08:47 AM
I believe you'll be fine unless you beat on it like a rented mule.
Old Jun 26, 2013 | 08:51 AM
droldsmorland's Avatar
CH3NO2 LEARN IT BURN IT
The 350/TH350 combo is a good one and should deliver decent torque. Your drive shaft specifically the Ujoints and rear end are now the weak link. Both should hold up for break-in unless you have wrinkle walls and do a smokey burn out at every stop sign.
Old Jun 26, 2013 | 01:22 PM
Sorry, I missed the fact that you were installing a TH350 with the 350 engine. Forget what I wrote.
Old Jun 26, 2013 | 05:11 PM
Redog's Avatar
I was told that a 7.5 10 bolt open can hold up to 400 ft lbs, with street tires.
I had a 7.5 open with 3.42's behind a 350/400 combo and I drag raced the car. My 350 was a stock one from a 68 Delmont with a 7111 manifold
Old Jun 26, 2013 | 06:29 PM
88olds350's Avatar
Thanks for all the replys and info guys. Helped alot! Thanks
rsandhoff
Jul 8, 2009 05:23 AM
mcutlass1969
Mar 9, 2009 08:54 PM
woodie582
Nov 9, 2008 09:06 AM
Pfiffle
Sep 22, 2008 05:10 PM
54olds
Apr 10, 2008 01:40 PM
