Will a 73-77 Cutlass rear end bolt into a 65 Cutlass
I've seen several posts about how a 64-67 A body rear end will bolt into a 68-72 A body and vice versa. With the main difference being the 68-72 rear end is 1" wider per side. Any chance the 73-77 Cutlass A body rear end will bolt in to a 65 Cutlass? Are the control arm mounts in a different location? Is that rear end even wider? Just wondering because I might have a line on an aftermarket Ford 9" rear end, but it is set up for a 73-77 A body.
Different
Drive shaft will need a cutting
Upper control ARM bushing mounts are in a totally different cast location
Spring perches are in a different location
whole rear is way wider...
Shall we keep going.
Sorry there are better options than this one out there.
Good luck on the hunt.
Jim
Welcome. I moved your post to it's own thread, as the original thread you responded to was about axles to fit a 65. You'll get better response with your own thread (though since Jim has already answered, that's about the best you'll get). Good luck and post some photos of your car as an intro.
350TurBRO
September 12th, 2014 11:52 AM
Mikes442
Drivetrain/Differentials
January 31st, 2014 03:57 AM
costpenn
September 16th, 2011 11:08 AM
