Will a 65 DIFF swap to 68?
Old Feb 15, 2014 | 06:22 PM
70worm's Avatar
Will a 64-65 Cutlass rear-end fit in a 68? Length? Spring mounts? Control arm mounts?
Old Feb 15, 2014 | 07:00 PM
66400's Avatar
It will bolt in but you will need to use the coil springs from the 64-65 rear end as they bolt to the housing. 67 and newer just slip in place,.
Henry
Old Feb 15, 2014 | 07:53 PM
507OLDS's Avatar
You can use the 68 springs,and bolt them in place,like they did in 65. The 65 springs are open at the top,and will not fit the 68 frame correctly.
The 64-65 rear is 5/8" narrower on each side,compared to the 68 rear.
tecar442
Drivetrain/Differentials
Oct 9, 2013 06:05 AM
falconsfan
May 31, 2007 04:33 AM
rsandhoff
Apr 8, 2007 06:02 PM
77supreme
Mar 12, 2007 03:42 PM
hubb
Aug 10, 2003 10:12 PM
