What rear end is mine?
Old June 3rd, 2011 | 03:43 PM
theoldsrocket's Avatar
http://www.youtube.com/wa
1972 cutlass s with 350 stock car what rear end would I have.
Old June 3rd, 2011 | 08:25 PM
2blu442's Avatar
If its the factory one it would be the corportate 8.5" ten bolt. Probably a non-posi with highway gears, 2.56, 2.78 or 3.08's. But you've got a desirable rear end for building if you want to change gears and add a posi. Read through some of the posts by Monzaz and 507OLDS discussing various rear ends. Yours has the best selection for parts and interchange from many different GM cars of the 1970's and I believe going into the 1980's. John
Old June 5th, 2011 | 04:34 PM
monzaz's Avatar
rear end type
You can also post pictures of the rear cover JUST to be sure someone has not swaped out the rear over 40+ years.
10 bolt 8.5 was used from 1970-1999 and renamed 8.5 from 1998 -2011 THe carrier bearings were increased in diameter BUT the ring gears from 1970-2011 are all interchangeable. Jim
Old June 6th, 2011 | 04:40 PM
Here are some pictures
Rearend
Old June 6th, 2011 | 09:33 PM
monzaz's Avatar
10 bolt 8.5
That is a 10 bolt 8.5 rear diff. I call them the BUICK 8.5 10 bolt because of the rear cover . The olds 10 bolt 8.5 usually has the round rear cover with half a oil trough. (reference picture)
Either way We have seen them under BOTH.
I would assume it is original If you have the axle tube suffix 2 letter code we could know for sure.
Jim
Old June 6th, 2011 | 09:48 PM
oldzy's Avatar
Here is my factory 8.5" 10-bolt rear end off my '72 Supreme...
Old June 6th, 2011 | 09:55 PM
Where can I find the code, is this any different because I'm about to get it rebuilt.
Old June 6th, 2011 | 10:43 PM
Will the W 27 cover fit this rear end?
Old June 6th, 2011 | 10:46 PM
w 27
this kind?
Old June 7th, 2011 | 05:57 AM
monzaz's Avatar
cover
YOU have a 8.5 10 bolt ALL 8.5 covers will fit the rear. So YES that cover as long as it has 10 bolt covers and is for 8.5 will fit your rear diff housing. NO WORRIES.... Jim
Old June 7th, 2011 | 07:25 AM
This is a 8.5 for sure or do I have to pull the cover to be exact because I need to order parts for it.
Old June 7th, 2011 | 08:49 AM
507OLDS's Avatar
That IS an 8.5" 10-bolt.That style came under all of the 71-72 Buick Skylark/GS cars,and it came under the 71-72 Cutlass/442 cars that were not built in Lansing Michigan.All of the Lansing-built 71-72 Cutlass/442's that I have seen,had the other style cover,like Monzaz & Oldzy posted a picture of.
The style with the notched cover,like yours,has a large "A" cast on the top of it,and on the sides,facing the front.The style with the round cover has an "O" cast on each side of the pumpkin,facing the front. BOTH are 8.5's,and BOTH takes the same parts.The W27 cover will fit both of them.
Old June 7th, 2011 | 12:44 PM
Makes sense mine was made in California. I'm going to get it rebuilt in the states and do posi with 3.42 gears.
Old June 13th, 2011 | 05:21 PM
Before I get my parts the guy wants to know if it is the bop style with bolt in axles? How many ring gear bolts hold the carrier? axles spline and gear and pinion gear?
Also this is the kit I am getting, any opinions on this stuff.
http://cgi.ebay.com/ebaymotors/GM-8-...ht_2766wt_1165
Old June 13th, 2011 | 09:09 PM
monzaz's Avatar
Oh MAn
Sounds like this guy is NOT to knowledgeable on the older rears...God help you....lol. Jim
IT IS A 8.5, ALL 8.5 rears use the same ring and pinion and parts in the center section area.
It is bolt in axles....ALL 1971 1972 8.5 A-bodys are. This will not make any difference on the rebuild kit he needs.
Axle bearings are A9 and seals are 712146.... MAKE certain he gets the correct SEAL or you are DOOMED! NOT THE 2146 MUST BE 712146
Good Luck! AND may the FORCE BE WITH YOU LUKE!!!
Old August 14th, 2019 | 04:02 PM
jwz's Avatar
jwz
Do you build 8.5 10 bolt rear ends and do you have a website?
Old August 14th, 2019 | 06:25 PM
bry593's Avatar
1968 442 Convertible
Jim, I had no idea the 10 bolt was used to 2011! I assume these must have been used in trucks? Which ones?
rab62184
Drivetrain/Differentials
April 22nd, 2015 06:51 AM
CutLS
March 24th, 2015 10:23 PM
michael hilsabeck
September 28th, 2011 09:46 PM
1965cutlassragtop
22
June 8th, 2011 09:11 PM
Kidcutty
March 16th, 2010 08:17 PM
