U joint part #
Old Sep 6, 2024 | 10:48 AM
72455's Avatar
1972 U code Supreme
U joint part #
Can anyone confirm that Moog part #235 is correct for my '72 Supreme?
Thanks.
Old Sep 6, 2024 | 10:57 AM
Yes, that is correct. The 235 comes with a grease fitting. Be sure to install the u-joint such that the hole for the grease fitting is in compression, not tension.
Old Sep 6, 2024 | 11:00 AM
72455's Avatar
1972 U code Supreme
I'm not sure what you mean Joe 🤔
Old Sep 6, 2024 | 11:53 AM
HydraMatic's Avatar
Does this help ?
Old Sep 6, 2024 | 12:10 PM
72455's Avatar
1972 U code Supreme
Originally Posted by HydraMatic
Does this help ?
u joint video
Wow...that's good stuff. Thanks for posting the link.
Old Sep 26, 2024 | 07:56 AM
72455's Avatar
1972 U code Supreme
So I'm at the shop now getting the pinion seal and U joints replaced, and the grease fitting for the U joints is actually on the cap. I guess the logic about compression and tension doesn't apply.
Old Sep 26, 2024 | 01:44 PM
The Heavy Duty greasable joints have the fitting in one of the caps, which makes the body stronger by not having a hole near the center of the cross. That is the style I use on my Jeep.
Old Sep 26, 2024 | 03:58 PM
72455's Avatar
1972 U code Supreme
That must be what the shop ordered because the grease fitting is definitely on one of the caps.
Old Sep 26, 2024 | 04:11 PM
Interesting to me since I never knew they manufactured U-Joints with grease zerks in the caps. I'm going to start looking for them from now on.
Old Sep 26, 2024 | 04:58 PM
72455's Avatar
1972 U code Supreme
You and me both...and they now have a new "cap style " grease fitting which uses a needle attachment.
Old Sep 26, 2024 | 05:04 PM
I have a needle attachment. First time I needed it I couldn't for the life of me figure out how to get it attached to the grease gun nozzle. Have to unscrew the grease gun nozzle, insert the needle adapter then tighten the grease gun nozzle to secure the needle adapter (at least on my grease gun). Had me bewildered how that needle adapter got inserted.
tkcutlass
May 21, 2024 04:02 PM
Cruzinbill
Jun 13, 2022 08:35 PM
Macadoo
Suspension & Handling
21
Jul 4, 2019 06:44 PM
leroycjr
20
Jan 10, 2018 03:48 PM
AJFink
Jul 11, 2016 06:47 PM
