Timken 712146 seals
Old Jun 16, 2023 | 11:34 AM
TOM1972's Avatar
Timken 712146 seals
Does anyone know where I can buy the correct all black seals that are "SUPPOSE TO MEASURE .490 at least"
The ones i just received from amazon are the black and gold ones. Thanks
Old Jun 16, 2023 | 01:26 PM
Rock Auto shows to have that seal from three different manufacturers.
https://www.rockauto.com/en/partsearch/?partnum=712146
The Timken seal shows to be .470" width.
https://www.rockauto.com/en/moreinfo...118794&jsn=270
Old Jun 16, 2023 | 02:09 PM
TOM1972's Avatar
thanks for replying Fun71, but according to some of the guys on here, the black and gold ones wont prevent leaking. Not really sure why I cant find the bigger ones online.
Old Jun 16, 2023 | 05:27 PM
Get in touch with Monzaz (Jim at JD Race). I think he was the one who alerted us about the seal differences, and he may be able to get you the right seal.
Old Jun 16, 2023 | 11:29 PM
OLDSter Ralph's Avatar
If I remember correctly, this is concerning the "Set 9" type O differentials. The new seals are only .470 thick. The originals were .495 or so, so they don't seal against the inner differential seal face.
The inner face needs to be more shallow for the .470" seal to work. That would mean welding and re-machining or a possibly a .025-.030" spacer of compatible material that would seal. I PM'ed Jim a while back when this seal problem popped up. The thread died out and I got distracted, so nothing went further.
Old Jun 18, 2023 | 09:17 PM
monzaz's Avatar
you can try skf 16735 they say .470 but seem to be pretty good.
If it were me I would really try to find the straight non tapered bearing made from ANY COUNTRY then the seal will not make a difference.
Jim
JD Race
Old Jun 20, 2023 | 10:00 AM
TOM1972's Avatar
Has anyone had luck with the straight rollover ones on ebay? Says they fit. Thanks
Olds Cutlass Supreme 1970-1977 Rear Axle Bearing (OEM Straight Roller Design)
Olds Cutlass Supreme 1970-1977 Rear Axle Bearing (OEM Straight Roller Design) | eBay
Old Jun 20, 2023 | 11:14 AM
BillK's Avatar
Just looking in my big National seal book it looks like a 470460 might work and it is .500 thick. The od is a little smaller but should still be a press fit. Might be worth trying ?
What is the actual application ? YMM ? I have some older books I can look through.
Old Jun 20, 2023 | 11:32 AM
TOM1972's Avatar
I have a 1972 8.5 olds rear. Been through a few sets of tapered bearings that still leak. Just trying to find a solution and get it back on the road. Thanks for replying.
oldcutlass
Oct 24, 2021 06:22 PM
Troys Toy 70
Feb 18, 2019 02:11 PM
sixty9olds
Body work
Jun 13, 2009 08:34 PM
KeithA0000
Oct 28, 2008 08:23 AM
lzbg17
Mar 13, 2008 08:47 AM
