thoughts on a perfect launch diff cover
Old Jan 3, 2014 | 06:17 PM
76olds's Avatar
Hookers under Hood
I was looking a replacing my old rusty rear cover when I do my posi unit and gears. I've read they reduce wear. Anyone using these or others ? The are 180.00 up here in Canada.
Old Jan 3, 2014 | 06:41 PM
If your referring to the heavy aluminum cover that include screws to add preload to the diff caps they do reduce wear. But it would have to be in a heavy car with some power and sticky tires for the benefit to really show. The preload screws help prevent the bearing caps from moving around under load.
Old Jan 3, 2014 | 07:06 PM
76olds's Avatar
Hookers under Hood
Thanks Matt, yes the heavy aluminum with the screws. My 76 is heavy with not a ton of power with Bfg tires. I Would really like to know if anyone has used them. I'm leaning more to the look I guess.
Old Jan 6, 2014 | 04:11 PM
jag1886's Avatar
I use one. Every rear I've ever shelled broke because the main cap snapped. I put one on my current car even thou it's not a big HP car, but I did spend a grand on the rear end and I figured it was cheap insurance.
Old Jan 6, 2014 | 05:00 PM
76olds's Avatar
Hookers under Hood
[QUOTE=jag1886;637598]I use one. Every rear I've ever shelled broke because the main cap snapped.
Wow that's crazy, I will defiantly put out the buck 80 for the cover that seems to be the cheapest of them all up here . Thanks Jag!!!
Old Jan 13, 2014 | 03:37 PM
76olds's Avatar
Hookers under Hood
Picked up my rear end cover today $198.00 cdn Its my cheap insurance. Thanks for your advice Jag !!! Transmission is next.
Old Jan 13, 2014 | 04:53 PM
tru-blue 442's Avatar
Old School Olds
Thumbs up Nice cover.
Hey 76, how's about a pic
of the other side too.
What vendor did you use?
Old Jan 13, 2014 | 05:51 PM
76olds's Avatar
Hookers under Hood
Here is the other side. I ordered it through performance improvements up here in Toronto Canada. The cover is aluminum. I had to remove the paint from the mating surface and just cleaned up the inside a little with emery cloth.
Old Jan 13, 2014 | 05:56 PM
Old School Olds
Nice, I like it.
Thanks for posting!
Old Jan 17, 2014 | 06:33 AM
monzaz's Avatar
Cover
How thick is the Aluminum where the cover bolts go through 1/2 3/4" ??
I use a derivative of T/A cover I found them to the one of the thickest covers around. The more Aluminum the better...
I race and do not use any performance cover at all. 10.50 2750 car.
Car is light But I also sell rear diff parts and try to get customers to understand that not always the trick parts are needed and that you should concentrate on the set-up and maintenance of the part.
For a Heavy A-body such as yours I would install it for sure you can use all the help you can get to keep it stable with weight of the car. Heavy car and lots of torque leads to broken parts. Jim
Old Jan 17, 2014 | 02:23 PM
76olds's Avatar
Hookers under Hood
The flange is .665 I guess they machined it down from .750 im just assuming.
I will do my best to install all parts correctly with the cover I purchased. If anything goes wrong and I make a mistake then I will give you a shout and order another set lol. Thanks for your continued support .
Eric
Old Jan 17, 2014 | 04:38 PM
monzaz's Avatar
Patients
Eric
Patients - take your time and think it through keep stuff clean and get the basics down. PAttern - Backlash - preload. Jim
HonestDave
Drivetrain/Differentials
27
Oct 23, 2019 07:40 AM
70OldsRear
Aug 22, 2011 07:16 PM
71 Cutlass
Mar 28, 2011 11:21 AM
oldzy
Dec 2, 2010 06:55 AM
380 Racer
Nov 1, 2009 04:37 PM
