Still No Clarification
Old Mar 17, 2014 | 07:05 PM
Daniel Marsh's Avatar
C.W. Griswold
O.K. I ordered a drive shaft today from the parts place and now again I am not sure if I ordered the right one. Why is this so difficult? It is a 1969 olds 442 W30 4 speed there shouldn't be 14 choices of u joints and yokes! I need to know is it a 1310 or a 1330 front and rear with clips inside or out? There has to be someone out there that can answer that so I can order what I need.
Old Mar 18, 2014 | 04:17 AM
507OLDS's Avatar
It is neither. The Olds used the 3R u-joints in the front & back.They make transmission yokes for all types of u-joints,and they make the 3R. That driveshaft would also be the same length as a 68-70 with TH350 and the O-axle because the small output 4-spds have the same length as the TH350.
Old Mar 18, 2014 | 05:33 AM
C.W. Griswold
That is odd considering all the parts books say the 3r started later as in mid seventies. My 84 h/o has 3r joints but either way that isn't one of the choices.
Old Mar 18, 2014 | 06:03 AM
507OLDS's Avatar
I've owned plenty if them,and they came with the 3R. They also used the 3R on the mid60's BOP 8.2" 10-bolt rears.
The 1310 & 1330 were the Chevelle joints.
Old Mar 19, 2014 | 05:29 AM
C.W. Griswold
Thanks, you are 100% right. I finally read the GM parts book and Saginaw 3r front and rear. Last question, 55.5" or 56" center of u joint to center of other joint for a length?
Old Mar 19, 2014 | 05:37 AM
507OLDS's Avatar
When I get a chance,I'll crawl under and confirm.
delta881972
May 16, 2013 08:02 AM
Delta88royal
Jun 11, 2011 10:53 AM
defiant1
May 3, 2011 08:52 PM
MDchanic
Jan 30, 2011 09:00 PM
dre
Jan 3, 2011 08:05 PM
