Standard vs. Limited Slip
Hi gang,
Can you please try to explain the difference in feel between a standard rear vs. a limited slip? I'm very used to standard rears in my Ninety Eights but I upgraded my black car to a limited slip and I can definitely feel a difference when cornering. Is it normal to feel what I would describe as a mild "rumble" when making turns? Is it possible that I didn't set the pinion 100% correctly when changing the seal?
I'm pretty new to limited slip rears so feel free to educate me here.
thank you,
John
thank you,
John
Did you include the anti-spin additive when you added the fluid? Get the GM stuff, aftermarket gear lube such as BFL used to include it but don't know about today, or what diff lube you used. Even well worn units will chatter on a tight corner such a fast U-turn without it.
http://www.summitracing.com/parts/na...FWlT4godvTkA7w
Can this be added to any weight gear fluid, with or without existing additive in the fluid that's in there? I'm wondering if I would need to drain the rear and start over again.
Hi gang,
thank you,
John
thank you,
John
John, my 1983 Regency Brougham had a limited slip out of the factory. Duh, I didn't realize that till I started feeling that 'rumble/chucking' on corners. Change of diff fluid (80/90) and a posi additive to the diff made it all go away. Once all that is done, really you won't notice any difference in the way the car drives, except it will not get stuck as easily.
Thanks again to both of you.
The rear is original and from a '72 Olds Ambulance/wagon. It's an Olds rear with the 12 bolt 2:93 limited slip. All I've done to it is a new pinion seal and new fluid and vent (and it was sandblasted and painted years ago as well).
When I pulled the pinion nut off, I made the mistake of not counting the turns BUT I actually have another spare rear with the same ratio and I used the count on that rear to reinstall the nut on this rear....not the most perfect method but I figured it had to be pretty close at least.
84oldsDelta88
December 22nd, 2009 06:27 PM
Nailhead 88
Drivetrain/Differentials
June 20th, 2008 04:05 PM
