Rear ID Help
Old Jul 26, 2014 | 07:51 AM
cycomiko's Avatar
Rear ID Help
I just picked up a rear. I"m trying to decode the letters and numbers on the pass side axle tube. Its 3TR G 084. I found that the 3TR is a 8.5 3.73 posi. My question is what is the G 084? Does the G mean chevy? Thats the only info I could dig up. I was told the rear came from a 87 Olds 442. Then there should be O not a G right? I'm confused
Old Jul 26, 2014 | 08:57 AM
oldsmobiledave's Avatar
info
This is definitely an Oldsmobile sources 8.5" differential with 3.73 gears & posi. A great find. It is a bolt in for any 1978-1988 RWD GM A/G body of that era. Could definitely have come from an 87 442 but it may also have come from an earlier model year.
Note that these rear ends use C clip axle retention. Best to upgrade if you are planning to go fast. Otherwise good into the 11s.
Old Jul 26, 2014 | 10:25 AM
cycomiko's Avatar
Thanks Dave. Are there any other numbers on the rear that will tell me what it came from? Holy S#@t Dave 79 Oldsmobile cars since 1989!!
Old Jul 27, 2014 | 09:02 AM
cycomiko's Avatar
This rear is going into a 80 Cutlass. I've read that I need to cut my drive shaft 1 inch. Going from a 7.5 to a 8.5. I thought there was about 3in play in the driveline anyway. Am I wrong? Or is it that the 8.5 driveshaft is 4in shorter?
Old Jul 29, 2014 | 07:53 AM
cycomiko's Avatar
Anyone?
nolabigdawg
Nov 16, 2014 06:45 PM
orthoK
May 16, 2011 10:10 PM
Nor Cal Andy
Apr 1, 2011 07:13 PM
MJAKS462
Apr 15, 2010 02:34 PM
