rear ends
Old Jan 28, 2010 | 03:33 PM
65oldsf85's Avatar
rear ends
Will a 68/69 chevy 12 bolt fit in my 65 f85?
Old Jan 28, 2010 | 09:27 PM
MN71W30's Avatar
Yes, the 68-72 is probably 1.25" wider, only 5/8 on each side. and you'll need a special u-joint.
Old Jan 29, 2010 | 05:14 AM
66400's Avatar
Or a 64-67 Chevelle driveshaft. Henry
Old Jan 29, 2010 | 07:13 AM
507OLDS's Avatar
You can also use a yoke from a Canadian 12-bolt.Those have a yoke that looks identical to the BOP 10-bolts & the 12-bolt O-axle,& uses the same style U-bolts & nuts to fasten the u-joint.
Do you know what the 12-bolt Chevy rear came out of?
Yes,all of the control arm mounts,spring mounts,& shock mounts are the same.Your existing coild springs will fit right over the raised cups on the later 12-bolts,or any other A-body rear(72-older).Yes,the 68-72 12-bolt Chevy rears are 5/8" wider on each side,so it will push your existing wheels outboard 5/8",so check to make sure you will still have good tire clearance.If it is a project,& you will be ordering new rims,then just make a note to get something with a deeper backspace,so you can recenter the wheel under the car.
idaholc
Drivetrain/Differentials
Nov 15, 2020 07:52 PM
gearheads78
Aug 23, 2009 08:26 AM
scrappie
Jul 21, 2009 01:29 PM
J-(Chicago)
Dec 11, 2007 07:08 PM
Olds64
Sep 25, 2007 08:19 PM
