Rear end upgrade
Old Nov 6, 2017 | 06:21 PM
Jwagon's Avatar
Rear end upgrade
Hey guys, I took my 89 cc olds and put in a rocket 350 with flat top pistons and a mild cam, Msd atomic fuel system. Ive rebuilt the trans with a valve box and governor from a grand national. My question is what rear end is in the wagon factory and what should i upgrade it to? Id still like to cruise 70mph but have a good launch off the line.
Old Nov 6, 2017 | 08:13 PM
Oldcoyote's Avatar
My 89 Custom Cruiser had a 403. Given the fairly large tires, I used a 3.90 rear. With the 4 speed overdrive, this was perfect.
My 88 Cutlass RWD, also a 403, has smaller tires and there I used a 3.73.
Old Nov 7, 2017 | 06:16 AM
olds 307 and 403's Avatar
Out of Line, Everytime😉
In a heavy wagon either the 3.73 or 3.90 is a good choice depending on tire size. I find this calculator very accurate with the lock up torque converter engaged. http://tech.oldsgmail.com
Old Nov 7, 2017 | 07:28 PM
Cutlass Fan's Avatar
Hope you have an OD trans if you want to cruise at 70 with a 3.73 or 3.90.
Old Nov 8, 2017 | 05:55 PM
That car factory has a 2004R and upgraded some parts.
Old Nov 10, 2017 | 09:01 AM
brownbomber77's Avatar
Pardon my ignorance...is a CC a Cutlass or Custom Cruiser? I guess I'm asking if it's a B or G Body...
Old Nov 23, 2017 | 05:32 AM
The Custom Cruiser is the B/C body which means 8.5" rear ends are an easy to find item.
steel-and-fire
Drivetrain/Differentials
18
Jul 25, 2017 08:51 AM
Alex72cutty
Oct 25, 2016 02:40 PM
350TurBRO
Sep 12, 2014 11:52 AM
Trebla781
Jul 15, 2014 03:42 PM
Stattiolds69
Mar 16, 2011 05:06 AM
