rear end question ???
hello everyone, i have a 71 cutlass and i want to put rear discs brakes on it. first i want to get a posi rear end, so i guess my question is this? what rear ends will fit on a 71 cutlass and what is the process of putting rear discs on the rear end. thank you much ! -Lee
10 bolt cutlas 1971 rear
I would keep that rear and make it posi . It is a good strong diff. If it is a true 1971 rear it will be a 8.5. , which means you can use any 8.5 posi unit from any 70's car including camaro, regal, trans am ,monte carlo, impala (10 bolt 8.5 rear), grand prix all 1973 -1977 car came with them. OR... you can do a 30 spline axles from Moser conversion and a 30 spline unit from a 1990 -1996 rwd car will work too . the 8.5 has huge aftermarket support posis bearing kits gears you name it.
If you close I will help you or build it . We have the Buick guy up grade there 8.5 71 72 rear all the time Moser 30 spline axles and Eaton 30 spline hd units and or spool. I will put them against any 12 bolt rear . Think twice before unloading that rear. Ok? Good luck on your choice.
1" on the drive shaft is good info the 8.5 rears have a longer pinion then any a-body car in the 1965-1972 muscle car era.
List of cars to get a rear from direct bolt in 1965- 1972
Chevelle
Monte Carlo
Elcamino
Gto
Tempest
Lemans
Skylark
Grand prix
Chevelle
Monte Carlo
Elcamino
Gto
Tempest
Lemans
Skylark
Grand prix
thanks gents !
thank you two very much for the information. you guys narrowed it done perfect. and after reading so many different things, it's good to get a straight answer ! i will let you know what i decide in the next couple weeks ! -peace - Lee
350TurBRO
September 12th, 2014 11:52 AM
