Rear end code location right side towards rear of car?
Hey guys, does anybody know the code for a 373? I believe the code for 342 is SF? And location is on the passenger side towards the back of the car? Anybody got a pick up location? I rotated the tires around once Drive shaft goes 3 3/4 so that’s 373‘s
found code P3 0343?
P3 0343
According to the 1971 Service Manual, the 10 Bolt 8 1/2 axle coded R3 is a 2.56 anti-spin. There are no P coded axles. To me, the stamp you show in the picture is R3, not P3
Being that your car is an A/C car, it would have come with the 3.23 or higher(lower numerically) ratio. Someone has swapped the original axle for the current 10 bolt
Information is contained in the 1971 Oldsmobile CSM (p. 0-6, Fig. 10A - Differential Identification Code)
So is it definitely not the orig hosing with updated gears?
