Rear Axle Chart 1972 Assembly Manual
Old Jul 12, 2018 | 12:05 PM
Louis's Avatar
Restoration is all about details, but I need some help reading the Assembly Manual for my '72 Cutlass Supreme Convertible. My car has the limited slip differential and gear ratio 3.42 that I find in the chart on page 4-093, giving code TM.
In the column Differential Carrier Assembly, under Tape Color Code, is mentioned Yellow and Green. Can anyone explain those colors to me please?
Furthermore, on page 4-094 a decal is presented, probably should be TM for my car? I still have to look to see if I can find a stamped identification on the rear axle as seen on that page.
Any help would be appreciated.
Old Jul 12, 2018 | 12:58 PM
This is a picture of the stamped code on my 1971 2.56 open axle (code R2). The stamping can be hard to see as there is usually some amount of rust and dirt on the axle tubes.
Old Jul 12, 2018 | 03:05 PM
anthonyP's Avatar
Is not the TM code, 3.42 ratio, for W30's only?
Has any one ever seen a K-code (McKinnon) manufactured rear axle? What models were they available on?
Old Jul 13, 2018 | 12:30 AM
Louis's Avatar
Thanks, Kenneth, Good to know where to look for the code and how it looks like. I don't know the code meaning of 1971, but probably the three last digits would be the day of the year the axle was built (the same as in 1972).
Old Jul 13, 2018 | 12:37 AM
Louis's Avatar
From the chart 4-092 it seems you're right: the 3.42 ratio was standard on the W30. Don't now how it ended up on my car, it was just this way when I bought it. I would like to check though what it really is - so I will take a closer look to find the axle code on my car.
Old Jul 13, 2018 | 06:22 PM
monzaz's Avatar
That manual seems to be for a 1970 and older... the 1971 1972 seem to be in the CHEVY spot as this was the start of corperate housing now.
12 bolt olds is on the back side of the passenger tube and usually up side down... only 2 digit (number letter combo or 2 letter combo) suffix code
So you just might have the wrong info.
sammy
Jan 10, 2016 12:32 PM
auto_editor
Drivetrain/Differentials
Mar 11, 2014 08:32 AM
Delta88conv455
Nov 21, 2013 11:03 AM
AZ455
May 3, 2012 07:49 AM
JOHNNY
Aug 6, 2006 07:21 PM
