O series and P series rears
Old Aug 15, 2022 | 05:20 AM
Wallie's Avatar
Difference between the 67 O rear and the P rear posi.
Old Aug 15, 2022 | 05:22 AM
Wallie's Avatar
Is one better, stronger than the other?
Old Aug 15, 2022 | 05:45 AM
Nothing interchanges between the two if that was your question.
Old Aug 15, 2022 | 06:02 AM
Oldsguy's Avatar
Past Administrator
Monzas is one to comment on these as well, maybe he can do.
Old Aug 15, 2022 | 06:17 AM
Wallie's Avatar
Just curious if one is stronger or better than the other. Rebuild parts availability? Their both 3:08 gears. I have a type 0 open rear with 3:23 gears. Would those gears work in the 0 axle posi I have?
Old Aug 15, 2022 | 08:04 AM
66-3X2 442's Avatar
The P type is a 8.2 ring gear and the O type is 8.5 ring gear.. As Joe said nothing interchanges EXCEPT the 28 spline axles with 70 axles being the exception. The 3.23 will go on the 3.08 carrier but will not work with a 3.42 carrier.The P type is a cone type posi and the O type is a clutch type posi.
Old Aug 15, 2022 | 10:26 AM
Wallie's Avatar
Thanks to all for the information. It's greatly appreciated.
Old Aug 16, 2022 | 10:14 AM
monzaz's Avatar
So to ad.... The cone type in GMs eyes is NOT a -unit... The clutch type O type 12 bolt cover 10 bolt ring is a re-buildable unit. The square tab clutches are a custom item these days I have a few sets on the shelf.
The cone type unit will require...USUALLY after 50+ year cones to be cut and a cleaning out of all the parts and re-shim and assemble the unit. USUALLY I tell people this can only be done once per unit.
Hope this added info help on your info also.
Jim
JD Race
Olds68swede
Drivetrain/Differentials
Jan 11, 2022 01:52 PM
scrappie
May 29, 2021 06:09 AM
scottr2200
Jun 23, 2020 09:20 AM
ben442
Jun 8, 2019 01:07 PM
Navarrat619@gmail.com
Feb 8, 2019 06:10 PM
