O-axle gears,still not coming
Old May 2, 2014 | 06:03 AM
507OLDS's Avatar
May/2014 was to be the date when the O-axle gears were to be back into production.Nope. Yesterday,I recieved a notice that my long-time order for the O-axle gears has been cancelled,so it sounds like it will be quite awhile yet,or never.
I am looking at another possibility for gears,but if I can bring them to reality,they will be at least $500.00/set. Don't all jump at once.
I am in the process of moving & buying another house,so I won't be pursuing this for awhile.
Old May 2, 2014 | 07:08 AM
boese1978's Avatar
So I should probably hang on to my new in the box 3.42's to supplement my retirement?
Old May 4, 2014 | 04:19 PM
Same here with a set of Richmond 3.90s.
Old May 4, 2014 | 06:22 PM
507OLDS's Avatar
Actually I might use the common 71-up 8.5" 10-bolt corporate posi. It would help with the process. Just alter the pinion program.
There is a few options to look into.
You can have anything made. Someone had these 5:37 O-axle gears made.Maybe I can run a triple overdrive with them.
Old May 5, 2014 | 08:36 PM
Boilerz25's Avatar
Who wants to sell the 3.42 or 3.90? I feel like someone should have started a business out of the demand.
Sean
Old May 22, 2014 | 07:27 AM
bkeese's Avatar
Brian,
What rear do you have in your 507? I assume it isn't an O-type. Are not the Chevelle 12 bolts stronger?
Old May 22, 2014 | 10:29 AM
507OLDS's Avatar
I had the original 8.5" 10-bolt housing in my 72,until 2006. It consisted of 30-spline Moser axles,Eaton posi,3:70 gears,and a W27 cover. I removed it and installed into a different car,and is still going today.
I bought a Moser 12-bolt housing,and built that with 33-spline axles,Eaton posi,3:73's,Strange billet yoke,and a W27 cover that is drilled for the Chevy pattern. I had no reason to build the rear,but I did want the future option to run a 3:55 ratio. In my opinion,the 8.5" 10-bolt and the 12-bolt Chevy are equal in strength,but I prefer the 8.5" 10-bolt due to availability of the housings,and they already have bolt-in axles.The factory 28-spline shafts can take a good amount of abuse.
Old May 22, 2014 | 12:57 PM
bkeese's Avatar
Thanks Brian, that's what I wanted to know.
Old May 25, 2014 | 06:51 AM
ransomolds's Avatar
i'm looking for a rear end for my '68 cutlass supreme.need a 3:08-1,with anti spin(limited slip).hope someone can help.i'm in northern wisconsin.thanx
Old May 30, 2014 | 05:00 AM
monzaz's Avatar
3.08
Well - I have a chevy 3.08 posi Completely rebuilt. I do not know what you are doing with the car but it will handle all the street you can dish out.
995.00 Housing is VERY clean too blasted primed and painted chassis black.
Brgrenier
Site Help
Sep 6, 2014 05:57 AM
boc23
Drivetrain/Differentials
Aug 29, 2014 02:23 PM
monzaz
Aug 7, 2014 11:12 AM
busman442
Jun 30, 2013 05:44 AM
monzaz
May 29, 2010 08:46 PM
