Moser stock replacement axel
Old June 2nd, 2020 | 04:39 PM
oldsmoboogie's Avatar
I was looking on Summit for better axels fo the 12 bolt in my 72 cutlass. Moser has stock replacement axels but they are 1/8 inch wider than stock. The reviews say you have to shim the backing plates to get everything to line up correctly. Has anyone used these axels or is there a better alternative to better axels? I’m looking to upgrade since I put a stronger 455 in it and I’m looking at running low 11’s to high 10’s.
Old June 2nd, 2020 | 06:10 PM
monzaz's Avatar
what 12 bolt do you have? Chevy? or the Olds 12 bolt?
If it is Chevy there are TONS of different axles for that.
Bolt in axles for the 12 bolt olds you only have a few out there or get custom race alloy ones made from Moser.
we carry Yukon axles for either bolt in 28 spline axles or the 30 spline c-clip axles.
and we can have Moser axles made for the bolt in axles
Jim
JD
Old June 2nd, 2020 | 07:04 PM
Chevy 12 bolt, what do you recommend for my application? Do you have a package with wheel studs? Do you suggest c clip eliminators?
Old June 2nd, 2020 | 10:26 PM
monzaz's Avatar
12 bolt chevy
What are you going to do with the car?
Power output
Tranny type?
Drum or disc brakes?
Old June 3rd, 2020 | 06:40 AM
The car is 70% street car, 30% drag strip. It has the stock drum brakes, and i run an auto with a 3000 rpm converter, no trans brake. I will not put a roll bar in the car so i will be limited to 11.50 passes for the most part. The motor is in the 600hp range and i run 295 50 15 drag radials. The car leaves well and would pull the front tires with the last engine and im over 100 more hp with this new engine.
Old June 4th, 2020 | 11:19 AM
monzaz's Avatar
disc brakes
If you use a econo disc brake kit (right stuff detailing Summit jegs etc) you will not need c-clip elim kit (the caliper will hold the axle in if you do happen to snap the axle shafts ) and you will not have any of the leak issues that seem to come with them and you will not chop up a good 12 bolt Chevy housing.
I would buy any aftermarket axle shafts...They are are pretty good these days from Summit base to Moser Strange etc.
Your hanging on the street more so elim probably NOT a good thing for this set-up
Those are my opinions.
hurstoldsal
April 6th, 2020 05:04 AM
71cutlass442
Brakes/Hydraulic Systems
September 20th, 2013 09:38 AM
MI455
Drivetrain/Differentials
June 14th, 2010 08:14 PM
oldzy
Suspension & Handling
March 10th, 2010 06:34 AM
thorpedo91
December 21st, 2008 07:41 PM
Quick Reply: Moser stock replacement axel
