Moser 9 inch in a 64 F85 build
Old Jun 27, 2011 | 04:54 PM
therobski's Avatar
Just installed the Moser 9 inch 3:50 gear set in my 64 F-85 build and it has the 64-72 GM axle housing ends that I'm going to order the rear 11 inch drum kit from Master Power Brakes. From there is a there a brake line kit that will fasten to the 9 inch axle housing with pre-bent hard lines that go from the wheel cylinder to the center distribution block and soft line?
Old Jun 27, 2011 | 08:35 PM
stan 65 cutlass's Avatar
dude your outa control
Old Jun 28, 2011 | 05:49 AM
therobski's Avatar
Stan not out of control, I"M TOTALLY GONE
Old Jun 28, 2011 | 06:55 AM
ROBZ442's Avatar
That looks great, was there any problems bolting it in? That is one of my long term goals except 2" narrower than stock if I can every get a motor to stay together.
Old Jun 28, 2011 | 09:14 AM
507OLDS's Avatar
Since the 9" has different contours compared to the 10-bolt & 12-bolt,you will need to hand-bend your own lines for a better fit.You could start with 12-bolt lines,and modify them around the center.
Old Jun 29, 2011 | 05:39 AM
therobski's Avatar
What type of fasteners would you use to attach the lines to the axle housings? Also I think the old soft line from the cross member and the distribution block will work, may have to make the bolt hole a little bigger to fit the stud on the Moser. Will be working on this week later,
Old Jul 2, 2011 | 09:47 PM
507OLDS's Avatar
You could drill & tap a hole on the top of the housing,to mount the T-hose,or possibly use your bracket frim the 10-bolt,and flip it around.
Old Jul 3, 2011 | 06:19 AM
therobski's Avatar
Brian, I may try and bend the original one. Since the car was original with a single master cylinder I need to locate a later year distribution block, master cylinder and PB booster. Looking into the after market and maybe the distribution block from a 70-72?
Old Jul 3, 2011 | 06:39 AM
gearheads78's Avatar
car guy
Rob the last one I did I made a simple braket the bolted to two of the carrier studs. I then bolted the factory GM T fitting to that braket and just made the lines from scratch.
PS you better get busy. Power Tour 2012 just released Detroit to Dallas
Old Jul 3, 2011 | 02:02 PM
therobski's Avatar
Your kidding? Man the 64 will never make it. Need alot more $$$$$$
Old Jul 3, 2011 | 10:09 PM
507OLDS's Avatar
OK.Convert the disc system to 71-72 disc parts,for the proportioning valve,and master cylinder.The 70's Camaro/Firebird prop valve will work too.
Old Sep 1, 2011 | 02:53 PM
therobski's Avatar
bracket for brake lines
Have you guys ever seen one of these brackets? I would love to get a hold of one for my project.
Old Sep 1, 2011 | 03:32 PM
507OLDS's Avatar
I've made my own,and with that type of girdle cover,I have also tapped the top of the cover itself,but not entirely through,unless you wrap the bolt with teflon tape to prevent oil from wicking through.
monzaz
Jan 14, 2014 07:24 AM
wildwillie1981
Apr 24, 2013 04:19 PM
timothypaul
Apr 17, 2013 08:35 AM
69 442 protour
Dec 9, 2006 09:25 PM
