M22 With a 3.08??
An M-22 is a close ratio transmission. With 3:08 gears starting off will require some clutch slippage. An M-20 is more suitable with those gears. Both will have the same engine RPM's at cruising speed.
The close ratio trans is a bad idea for street use anyway. Unless you must have the M22 for bragging rights, sell it for stupid money (since it's not original to your car anyway) and get something with a much wider spread from low to high. Assuming you want to stay with a four speed so you don't have to mess with tunnel mods, look for a Super T10 with the 2.88 first gear. That, in combination with a 3.08 rear gear will be very nice as an all around driver. Just FYI, my 70 W30 had a non-original 3.08 rear when I got it. Coupled with the M21 close ratio trans, it really sucked off the line.
Your problem is taking off from a stop. Like mentioned above, you would want an M-20. If what you have is a true M-22 then you could sell it for twice the price of what you could get an M-20 for.
As always, math is your friend. The 2.88 first gear in the Super T10 will make those 3.08s feel like 4.10 gears with the close ratio Muncie off the line.
2.88 x 3.08 = 8.87 effective final drive ratio in first gear with the ST10.
2.20 x 4.10 =9.02 effective final drive with the Muncie.
The difference is that in fourth, you've got 3.08 gears, not 4.10s.
Most M-22's came in Corvette's, Camaro's, or Chevelle's. It will be stamped with a partial vehicle serial number and the final assembly plant code. Someone may REALLY want that transmission. Do your research.
3.42s were just about the lowest numerically gears you could get from the factory with the close ratio Muncie. Still only a 7.52 effective final drive ratio in first, but better than the 6.78 you'd get with 3.08 gears. Rule of thumb is that you want to be around 9:1 in first.
Hi,
I have a M22W from Autogear, basically a new version of a Muncie with wide ratio gears similar to a M20 with the straighter cut gears like a rock crusher/M22
Autogear also makes a rod race version with a 2.98 first gear if memory serves and were designed to run a 3.08 gear as a option?
Regards
Regards
Hi,
Regards
Regards
Years ago I had a 70 Supreme 4 speed that came with a wide ratio and 3:23's. I changed it to a close ratio and 3:90's. I decided 3:90's suck on the street so I changed the rear to 3:42. That setup took a lot of clutch to get going, so I went back to the wide ratio.
Wide ratio and 3:42 is a nice setup, very quick off the line.
Good luck!
Pat
I still have the Super T10 I got in 1978, 9310 nickel gears, nodular main case, aluminum tail, 26 spline input and turbo 400 output, 2.88 first ratio. It was arguably the best/strongest Super T10 ever made. I had it in #24 before selling the car. In 1966, Olds published a guideline brochure telling people that they should get the wide ratio M20 unless the diff ratio was 3.91, iirc.
May well be saying what has been said already but I have some first hand experience with M22 & 3.08. I worked on a 67 SS with a whooped M21 that locked up & 4.11. I put him into an Autogear M22 which I found to be a great shifting, nice trans. Then he decided the 4.11 was intolerable driving to the beach between CT & RI. He opted for a 3.08. You really had to feather & ride the clutch with that setup, especially starting uphill even with a stout BBC, a far cry from the 4.11 sweetness.
M-20 and 3.08s
funny my car came with the m-20 and 3.08 posi ( 350 ) so if I look what Joe was saying and do the math 2.52 x 3.08= 7.7616 which seems a far cry from the recommended 9.1? but I don't recall this car having issues off the line or being a dog in first? I now have swapped in a 455 in I certainly don't want it to be a dog off the line? I thought about that when I put new clutches and bearings etc in maybe I should have upgraded the gear ratio? kicking myself a little now... I am not drag racing the car but would at least like to feel like a musclecar..LOL... and if possible beat my wife in her hemi rt Durango in the quarter mile ( 14.7 I believe )
#32
"Talk me out of it please.
I can think of no better way of getting to 3.5's
I don't want to go tpo the trouble of converting the diff to 3.42 and hate it.
1000.00-ish for that or 2000.00 for the 9" plus I get disc brakes!!
#33
not to mention having a couple of pumpkins on the shelf for all occasions a lot cheaper and easier to swap gears LOL....
#35
1) The difference between 3.42 and 3.5 is so negligible as to be virtually undetectable on the street.
2) Unless you're going road racing, the difference rear discs will make will also be unnoticeable.
3) Why are you married to the M-22? As suggested above, sell it for a bundle of money to some guy who needs it for the correct restoration of a ZL-1, buy a Super T-10 with a 2.88 low and all your problems are solved. What's so hard?
#37
