identify differential 8.5?
Old June 25th, 2021 | 10:21 AM
jmcghee's Avatar
Old June 25th, 2021 | 12:22 PM
If you are asking for help in identifying if it is an 8.5" rear or not, I'd need to see more of the housing.
Does it have a boss on the top of the center section for the brake hose? If so, that points to 8.5" 10 bolt.
Are there two parallel ribs on the sides of the center section?
What is the casting number on the snout area of the center section?
If you're asking to identify the carrier, gear ratio, or something else, you need to ask a specific question.
Old June 25th, 2021 | 01:36 PM
66SportCoupe's Avatar
It looks like a 8.2 rear.
Old June 25th, 2021 | 02:15 PM
Jeff Stout's Avatar
Old June 25th, 2021 | 02:18 PM
BackInTheGame's Avatar
If you want to know the gear ratio, rotate the Ring Gear until you can read the stamped legend(s) on the outer edge. They will tell you the tooth counts and therefore the ratio. There is good info on ID'ing Olds differentials at this link at Supercars Unlimited.
Old June 25th, 2021 | 05:40 PM
jmcghee's Avatar
Trying to determine if it is a 8.8 or 8.2 housing. Do not care about ratio. It has a cover like an 8.2. It has the square lugs on the bottom of the center section like an 8.5 I have asked for more pics and casting numbers.
Old June 26th, 2021 | 09:41 AM
jmcghee's Avatar
Mystery solved , it is an 8.5 The center picture in the posting by Jeff confirms it Found an old post by Monzaz that confirms also thanks guys
Old June 30th, 2021 | 04:55 AM
monzaz's Avatar
10 bolt 8.5 absolute.
Maverick
Drivetrain/Differentials
19
April 8th, 2017 08:44 AM
Bobby455
19
February 21st, 2017 02:48 PM
wbaddawg48
June 1st, 2015 05:22 PM
djhoth
August 12th, 2011 12:43 PM
300F
June 24th, 2011 09:57 PM
Quick Reply: identify differential 8.5?
