Help Identify this Limited Slip Carrier
I only have pictures to go on. Anyone know what this is and what it's potential application? Supposedly, it's from a '72 442.
3E33p83of5Nf5Ec5H9cbhe5217e8532041f3a.jpg 3E63M33p15Ge5E75J7cbh1731de8f80991991.jpg 3E13Ia3M45E95W65M4cbh7fcbad8fc0be1b51.jpg
Posi unit info
These are from 1977-1983 ish era
They are c-clip axle type units
28 spline axles and SOME very few 31 spline wagons rears
ring gear diameter is about 8.750
The ring gear bolts are 7/16" left had thread
The ring gear IS the same bolt pattern as the 12 bolt chevy 1965-1972 era BUT the bolt holes are too large and the actual carrier width is wider than the chevy 65-72 era.
There are 3 series 17-1 17-2 17-3
17-1 holds the 2.28-2.56
17-2 holds the 2.73-3.08
17-3 holds the 3.23 and up
They came in Full size Caddy deville - wagons in the Chevy Buick Olds Pontiac rear wheel drive
Cover of the housing will have 10 bolts Will look like a PONTIAC GTO cover but larger- will have 12 bolts on the ring gear reference picture for the rear end type.
Jim
Nailhead 88
Drivetrain/Differentials
June 20th, 2008 04:05 PM
