Help with identification
neat
10 BOLT 8.5 REAR
IT IS SOME FORM OF A TORSEN POSI (TRUE TRAC WORM GEAR POSI... )
I can not tell if that is old school first design torsen posi or New unit ... to me it looks old school first design torsen posi ... It is a cool find for sure. I would love to see if there are any markings or casting numbers date codes? More pictures? What kind of bolts hold the unit together? Hex head Allan head???
Oh by the way the pattern is too deep on that set-up
You should take some shim out from under the pinion and reset backlash again. Needs to move up and out for the root of the tooth .
Jim
JD Race
Jim
JD Race
example
12 pinion into 41 ring is 3.41666666 Round up 5 or higher to the second decimal is 3.42
11 pinion into 41 ring is 3.7272727 Round up 5 or higher to the second decimal is 3.73
Hope this helps.
There are NO markings at all on the ring or the pinion head / crown? Jim
Hope this helps.
Daffy's Trike
Drivetrain/Differentials
May 3, 2009 08:47 AM
