Gear ratio on a posi
Old Oct 24, 2018 | 08:52 AM
RoyaleBrougham88's Avatar
I obviously own an 84 Oldsmobile Delta 88, it’s got a 307 with a 4 speed auto, and a posi rear end. I was attempting to do some research but I guess my car isn’t really common or something, so I couldn’t find anything in the rear differential gear ratio. I found the transmission ratios but no differential ratios. Any help would help me
Old Oct 24, 2018 | 09:34 AM
Does that year vehicle have an RPO sticker somewhere, such as in the trunk? If so, it should have that info.
droldsmorland's Avatar
CH3NO2 LEARN IT BURN IT
Count the number of tire revolutions to drive shaft revolutions. That will get you in the ball park. Pull the cover and look at the ratio stamped into the ring gear. Probably could use a rear gear service any how. Likely a high 2 or low 3 series.
Old Nov 18, 2018 | 04:42 AM
78Cutlass4Speed's Avatar
According to the 1984 Dealer album, 2.73's were the standard gear set for the Delta 88 with the 307 V8 and 4-speed overdrive transmission. 3.08's and 3.23's were optional (with the HD cooling) except in California. High altitude cars got 3.23's standard. As Fun71 said, there should be an RPO sticker (most likely in the trunk on the lid) with all of the codes on it.
GU2 = 2.73
GU4 = 3.08
GU5 = 3.23
G80 = limited slip (posi)
Old Nov 18, 2018 | 11:05 AM
Just looked at it has two codes on it, GU2 and G80. So I’m assuming that it has 2.73 gears and limited slip right? I know for a fact it’s posi though
Old Nov 18, 2018 | 11:15 AM
Yes, correct. It is a 2.73 posi.
Old Nov 18, 2018 | 11:18 AM
Got it thanks for the help!
jmos4
Jun 5, 2018 05:32 PM
Mikey_mick
May 10, 2017 07:17 AM
bigdooly
Drivetrain/Differentials
May 22, 2015 05:03 AM
White_Knuckles
Mar 23, 2014 10:38 AM
65Delta88
20
Jan 14, 2009 07:15 PM
