Driveshaft Concerns
Old Mar 31, 2013 | 09:03 PM
  #41
costpenn's Avatar
So sorry we did not figure this out months ago when you first brought up the issue. Glad that it did not create any other issues.
Are you kidding? You guys have helped me so much on this project.
Got it all put together tonite with new straps and another rear U.S. made U-joint. Was able to save the TR bolts. The bolts sold with the strap kit were about 3/8 shorter than the originals and I just don't want to take any chances.
Old Apr 15, 2013 | 09:45 PM
  #42
Tony72Cutlass'S''s Avatar
Originally Posted by costpenn
I believe, but now I'm not sure of anything, that mine uses the inner clips on all four cups of the front joint, and the two pressed in ones to the shaft on the rear one. They look and feel right.
Hey Joe,
i'm going to be doing my driveshaft for good measure this week. my new u-joints are in the mail.
how do you know whether i'll need pressed in clips or inner clips?
I find this all very confusing, i know i need to torch out the old nylon retainers.
As always, standard TH350 driveshaft with open 2.73 axle..
Old Apr 16, 2013 | 05:50 AM
  #43
droldsmorland's Avatar
CH3NO2 LEARN IT BURN IT
Google U-joints and it will be very clear to you. Both styles get "pressed" in. If you have never performed a u-joint service you tube it. There are some things you need to be careful of and various dos & donts. One example is there should be no bind in the joint once the new joints installed. How do you fix it if it has bind etc...Do not get any dirt in the new cups. I like to repack the cups with my favorite grease. Especially the non grease-able joints. There is a couple of different approaches to removal & installation. Sometimes you have to burn out the originals if they are held in with the plastic injected retainer. Sometimes a vice will work well sometimes a 20lb sledge will work better. Be careful not to whack the shaft or the yoke.
The other option is find a drive-shaft shop and for $20 they will install them.
Old Apr 16, 2013 | 05:51 AM
  #44
The new joints will come with whatever clips they need, Tony.
Good luck!
ps: still got frost in the morning? we still did yesterday.
Old Apr 16, 2013 | 06:55 AM
  #45
Good luck!
I had to scrape frost off the windshield of the cutlass. never thought i'd see that coming in mid april...
Old Apr 16, 2013 | 10:09 AM
  #46
In other news, i bought this one.
So it depends on the U-joint that i buy, not the driveshaft that i have?
Old Apr 16, 2013 | 10:21 AM
  #47
I believe different assemblies are different.
I will admit I never really thought about it - I just go to the auto parts store and ask for a joint for my car, and the one they give me fits and has the right clips.
Old Apr 16, 2013 | 10:30 AM
  #48
OK cool, i Bought whichever one was listed on Rockauto for my car with the right GM number and everything.
I just read the beginning of this thread. it's the same one Joe purchased for his car. It says the same U-Joint was used by GM until 2007??
costpenn
Nov 16, 2012 04:06 PM
Seff
Nov 15, 2012 07:48 AM
62radarlove
Mar 7, 2012 09:23 AM
scott_442
Paint
Feb 5, 2009 01:39 PM
nonhog
Oct 7, 2008 06:44 PM
