drive shaft question
Old Oct 24, 2018 | 09:47 AM
67Rocket's Avatar
What problems would be encountered using a two piece automatic transmission driveshaft from a 330 engine in a manual transmission car with a 400 engine? Thanks
Old Oct 24, 2018 | 10:12 AM
Depends on how you drive it and the current condition of the drive shaft. It could lead to vibrations that may eventually damage your transmission and/or your rear end or complete failure.
Old Oct 24, 2018 | 11:51 AM
The worst thing that will happen is that you'll dump the clutch and shear the rubber to metal bond, rendering it useless. Run it until it breaks or until you can afford a solid shaft.
70convert
Drivetrain/Differentials
Mar 7, 2019 02:12 PM
harriscu
May 15, 2016 09:45 PM
Robert Kiedrowski
Jun 28, 2015 05:22 AM
johnnyjaws
Sep 4, 2014 12:07 PM
chrisneu68olds
Mar 21, 2012 12:40 PM
