drive axle snap ring
Old Nov 7, 2020 | 07:46 AM
lawsrolf's Avatar
Hello anyone out there know where I can find a snap ring for the drive axle that goes inside the differential on the driver's side?
Old Nov 7, 2020 | 09:28 AM
I'm guessing you are working on a Toronado, but what year and transmission?
Old Nov 8, 2020 | 07:36 AM
lawsrolf's Avatar
It's a 79 Toronado with a TH325 Tranny. I spoke with a Summit Racing guy yesterday regarding this situation for about 45 minutes. I think we might have it worked out, however you might have a suggestion and I would welcome it as well. This part that goes into the differential is a flange on the outside and has a spine shaft with a groove on the end of the shaft. This inserts into the differential and the flange on the outside connects to CV Axle with 6 bolts approximately. The Summit Racing guy said that what holds the flange with the shaft inside the differential is a C-Clip which I ordered from Yukon Gear & Axle. What do you think?
Jul 2, 2020 03:28 PM
slade69
Drivetrain/Differentials
Jan 16, 2020 03:35 PM
enginenine
Oct 13, 2015 05:00 AM
jtdb153
Aug 12, 2013 10:28 AM
olds1968
Apr 18, 2008 08:39 AM
