Differential code
I believe SA is a type o 2.78 ratio,1967-1970. 12 bolt cover.
but I don't think that applies to an 8.5" (10 bolt cover), which should be what you have in the 72.
Sorry I am of little help.
Thanks, right down to the day
Does anyone have tips on replacing the pinion and ring on this rearend...I'm wanting to go to 3.23...will the change make that much of a difference?
R350
compXE262
new comp springs and lifters
3 angle VJ, valve guides etc...stock 7A
Ruggles built quadrajet (performance)
stock intake (debating on rpm, not sure worth the $)
stock pistons and rehone (build measured out by builder and in spec)
crank ground 10k
R350
compXE262
crank ground 10k
You will notice a difference between the 2:73's & the 3:23's,but with a 350,and that build,I would put more gear in it.At least a 3:42,maybe a 3:73,depending on how/where you are plenning on driving the car.The don't offer any ratio between the 3:42 & the 3:73.
I'm trying to decipherer a used differentials transfer casestamped code on my '72 442/R350, "SA B354 1"...
any ideas?
any ideas?
nj_cutlass72
Drivetrain/Differentials
March 18th, 2013 04:31 AM
