Curious rearend question
Old Dec 23, 2011 | 06:19 PM
projectheaven's Avatar
Will a 10 bolt posi rear end set up drum to drum fit a 68-72 A body Cutlass?
Old Dec 23, 2011 | 06:46 PM
svnt442's Avatar
That's kinda vague. What did it come out of?
Old Dec 23, 2011 | 07:01 PM
507OLDS's Avatar
If it came out of a 64-72 A-body,it will fit all other 64-72 A-bodies.
Old Dec 23, 2011 | 07:08 PM
I apologize for that. It's out of a 78-88 g body car. (El camino,cutlass, Monte carlo)
Old Dec 23, 2011 | 11:52 PM
svnt442's Avatar
Don't do it.
1. It's too narrow.
2. It's WAY too weak and will go boom in short order.
Old Dec 24, 2011 | 12:25 AM
WoW!!!! Got it!
Old Dec 25, 2011 | 07:14 AM
monzaz's Avatar
Rear end swap
Other reasons beside strength -
Upper control arm mounting and lower control arm mount and spring perch location are all in different locations and angles. SO the fitment will cause bind in the suspension travel also.
A-body GM platform(64-72) is different that the G-body GM platform (78-88)
And then you have the 1973-1977 GM A-body platform which is WAY different then both of them...
Stick with your era there are plenty out there still to choose from.
82 Grocery Getter
Site Help
Apr 30, 2009 03:08 PM
78cutlass
Site Help
Jan 25, 2009 05:39 PM
54olds
Brakes/Hydraulic Systems
Jun 25, 2008 12:46 AM
BlueBlock350
Mar 28, 2008 01:51 PM
Molly
Mar 23, 2008 07:20 AM
