can i put a 73 el camino rearend in my 1970 cutlass
Old Jan 26, 2014 | 03:07 PM
Iggyg00's Avatar
like the title states can i put a 1973 el camino rear end in my 1970 cutlass?
looks to be a 10 bolt rear end in the el camino.
want to put a posi in my cutlass and it looks to currently be a 2.56 peg leg.
This is what I found on my olds rear end r2 stamped on the front side of the passenger tube.
carrier has 402227 cfd5
any help is most appreciated.
or what would it cost to update the current to a locker wiht 3.73 or 4.10
Old Jan 26, 2014 | 03:38 PM
2blu442's Avatar
Sorry but no, the 1973 is wider and the ears on the center won't line up with the upper control arms. If the price is right, you can buy it and pull the posi carrier out of the 1973 housing to use it in a 1971-72 Cutlass housing.
But for your 1970 the factory rear end was the type O and parts are not as available as other rear ends. You may try contacting Jim who goes by monzaz or Brian who is 507OLDS as both of these members buy/sell/trade and restore rear ends. I believe that at one time Jim was having posi carriers manufactured for the Type O rear end. One of these guys may have the parts to convert your rear end over or have a complete rear end with the posi setup already in it.
John
Old Jan 26, 2014 | 03:44 PM
Iggyg00's Avatar
thanks for the info... I was at a local lkq and it was the only one there that looked close. they also had a jetstar88 not sure what year vin was 35269 6e148032
Old Jan 26, 2014 | 03:49 PM
2blu442's Avatar
There's been a lot of discussion about what will fit under which years as most of us want to upgrade to the posi, or as Oldsmobile called it the limited slip rear ends. If you have time you might go through the section of transmissions/differentials and read through some old posts. If you have an idea what will fit your car, then scour Craigslist within commuting distance and watch the local wrecking yards. If you know ahead of time you can pull the trigger when you come across a good deal. But don't hesitate to ask if your not sure about applications.
John
Old Jan 27, 2014 | 08:13 AM
The "6" in the sixth position shows this to be a 1966 model year car. In any case, the J88 is a B-body. That won't fit either.
plee3 64Olds
Suspension & Handling
63
Jun 17, 2013 06:06 PM
rhett838
Apr 22, 2012 08:21 PM
BosMobile
Site Help
Aug 12, 2009 04:41 PM
easytobedead
Aug 27, 2008 10:25 AM
69cutlassgirl
May 24, 2006 10:07 PM
