Better gears for my 1980 delta 88
Old Jul 29, 2009 | 09:11 PM
80delta350's Avatar
i was wondering if anyone knew any interchangable rear-ends for my 1980 olds delta 88 to make it have better gears in the rear?
Old Jul 29, 2009 | 10:27 PM
Redog's Avatar
Just get either a new rear end, or swap out that 2 series 7.5 carrier, with a 3 serise posi carrier and throw 3.42's in it
Old Sep 2, 2009 | 04:54 PM
Kennybill's Avatar
I've never tried it but 1973 to 1977 A-bodies, Cutlass,chevelle/malibu, rear-end housings are bolt-in for 1978 and up B/C bodies. Lots out there with posi' & better ratio's. Ken
Old Sep 2, 2009 | 05:59 PM
J-(Chicago)'s Avatar
Seasoned beater pilot.
X2 on the 73-77 A body rears. They are a 1/2" shorter, but they'll go in just fine.
Old Sep 3, 2009 | 04:44 AM
monzaz's Avatar
swap
The 73-77 are the same width as the 1978-1996...Same mounting points upper and lower and spring perch mounts. The early 1971-1977 full size rears are wider than the the 78-96 b-body... (wagons are an exception on this rule they are wider)
There also will be a rim / wheel bolt pattern difference too from 5 on 4 3/4 73-77 A-body and 5 on 5" full size 1971 -1996 b-body...One exception here is the impala base model will some times have the mid size car 5 on 4 3/4" bolt pattern circle and smaller 7/16 or metric studs. Jim
Old Sep 3, 2009 | 04:46 AM
monzaz's Avatar
swap
Oh and the yoke may be different too with a standard Y type yoke or bolt on coupler type (round flange) BUT they are easy to interchange to what you need on the 8.5 10 bolt rear. Jim
Old Sep 3, 2009 | 04:45 PM
Do you have any driveshaft side yokes to match the companion flange style pinion yokes?
1969camaross350
Oct 1, 2025 03:22 PM
boc23
Drivetrain/Differentials
Aug 29, 2014 02:23 PM
monzaz
Aug 7, 2014 11:12 AM
monzaz
May 29, 2010 08:46 PM
J-(Chicago)
Jul 27, 2007 01:50 PM
