Axle date code
Old Oct 17, 2011 | 04:38 PM
AZ455's Avatar
1974 DELTA 88
Axle date code
Was wondering if anyone had the means to decode the diff ID code on the axle tube. I got part of it figured out.
UA P 029N
I found the following in my service manual:
Open diff.
2.73 gear ratio from the UA
8-7/8" ring gear from the P
What is the date code, as well as the N at the end of it?
Thanks.
Old Oct 17, 2011 | 07:17 PM
AZ455's Avatar
1974 DELTA 88
Just thinkin...
029N = 29th day of November?
Old Mar 10, 2012 | 08:55 PM
Originally Posted by AZ455
Just thinkin...
Your thinking is probably mostly correct. The O is really and "OH" for Olds axle. Other than that I think you nailed it. I just found this thread on a related search.
Old Mar 12, 2012 | 08:50 AM
507OLDS's Avatar
When was your car built?The 029 should mean the 29th day of the year,which would be Januray 29th.The "N" could be the plant code.
Old May 2, 2012 | 10:58 PM
AZ455's Avatar
1974 DELTA 88
Wow, forgot about this thread. I just found it again searching for gears on Google...
I'd have to check and see exactly when the car was built.
While I've got you all reading this old thread again though.... anyone know what gears are available for this 10-bolt 8.875 rear end? I'm not really finding any info out there. I heard there isn't much aftermarket for the 10 bolt GM 8.875 car diff.
Old May 3, 2012 | 05:30 AM
507OLDS's Avatar
No,there isn't much available for those.Every once in awhile,you might see a set of 3:23 gears for these rears pop up for sale.
Old May 3, 2012 | 07:37 AM
AZ455's Avatar
1974 DELTA 88
You mean a set of 3.23s from out of another Olds, or new?
Are these diffs the 10 bolt cover 12 bolt ring gear I've heard of? If so, the gears for regular GM passenger car 12 bolt 8.875 I see for sale all over would not work, would they? Browsing the net it's like these didn't ever exist!
Thanks.
Old May 3, 2012 | 07:44 AM
507OLDS's Avatar
A used set,from another car.
Old May 3, 2012 | 07:49 AM
AZ455's Avatar
1974 DELTA 88
Well I found these...
http://stores.ebay.com/Fabcraft-Meta...=p4634.c0.m322
Anyone have any experience with them? Seem to be only available in 3.55 though... and somewhat pricey.
Boiler_81
Sep 22, 2020 02:05 AM
GEARMAN69
May 22, 2015 10:58 AM
gmsteve455
Mar 25, 2014 07:02 PM
1320dragmonza
Tech Editor's Desk
Aug 17, 2013 04:44 PM
Boldsmobile
Nov 2, 2011 06:02 PM
