axle
Old Jan 2, 2010 | 12:10 PM
bigwillystyle's Avatar
new user
axle
when you put the axle into the housing or the tubing after putting on new bearings should the bearing be flush with the housing or the tubing or does it stick out a little bit.
Old Jan 3, 2010 | 06:32 PM
svnt442's Avatar
What axle are you working with? From what I know the bearing needs to be recessed so you can install the axle seal in the end of the tube.
Old Jan 4, 2010 | 08:22 AM
new user
thanks but my dad started to take things apart again and he figured out that the oil seal was in backwards so we solved the problem.
cutlasssupreme71
Drivetrain/Differentials
Feb 22, 2011 11:40 AM
dan1s
Sep 23, 2008 01:53 PM
dan1s
Mar 16, 2008 11:13 AM
<powers455>
Sep 13, 2007 09:11 PM
Old School
Sep 4, 2007 09:11 AM
