83 old custom cruiser
Hello everyone. I am a Newbie in need of help.
Our 83 custom cruiser, which has been with us from new and served us very well, has developed a problem with the limited slip. Looking inside the 10 bolt pumpkin shows no wear on the crown wheel and pinion but bad wear on what I am assuming are the small gears associated with the limited slip. I have tried to identify the type/model of the diff in order to search for parts, if still available, but research hasn't helped any. Any help would be very appreciated.
Well, your Chassis Service Manual has complete information. In any case, Google 8.5 gm axle. This is probably the most common Chevy axle ever made. Parts for it just about grow on trees.
Took a look underneath and the prop shaft is not rotating in forward gears. Loads up and moves in reverse. Fluid level good.
Any thoughts on this would be helpful before I drag her out and jack her up.
Thanks for the help so far Guys.
Fred Kiehl
June 16th, 2013 04:55 AM
317Cutty
February 4th, 2013 08:34 PM
supertrucker1978
April 24th, 2012 07:09 PM
