8.2 or 8.5
Old June 24th, 2011 | 10:25 AM
300F's Avatar
8.2 or 8.5
Help !!!!!!!!
Wath rear is in mine I have a 1971 442 with a 10 bolt axle without posi
but i dont no what kind of axle is in mine it is all original is it an 8.2 or an 8.5
so I can order an powertrax from Richmond
Thank you
Old June 24th, 2011 | 10:31 AM
halfmoontrail's Avatar
8.5 in '71
Old June 24th, 2011 | 10:46 AM
300F's Avatar
You are sure
Can I use a powertrax from a 8.2 carrier in a 8.5 carrier
Old June 24th, 2011 | 10:47 AM
300F's Avatar
both are 28 spline
Originally Posted by 300F
You are sure
Pretty sure that '71 and later A-body moved to the 8.5" ring gear. Also pretty sure that the 8.2 inch components DO NOT interchange.
Steve
Old June 24th, 2011 | 08:15 PM
507OLDS's Avatar
You need the PowerTrax unit for an 8.5" with 28-spline axle.Part # 1920LR. These are different than the 8.2" units.For what they want for those PowerTrax units now,you can get a rebuilt used posi,or some new posi units.
Old June 24th, 2011 | 09:57 PM
300F's Avatar
re axle
OK thank you all for the fast answers
