71 98 Posi upgrade
Old Jun 19, 2012 | 06:51 AM
7198Coupe's Avatar
71 98 Posi upgrade
Completely new to rear end work but have lift and time. Can I upgrade the stock r/e to posi or do I have to relpace the entire r/e axle set up. I plan on rebuild the current engine/tranny around 400hp. Thx
Old Jun 19, 2012 | 07:05 AM
67442HT's Avatar
You should be able to buy a posi carrier assembly and install in your current differential with whatever ratio gears you want to run.
Old Jun 19, 2012 | 07:28 AM
AZ455's Avatar
1974 DELTA 88
Which rear end do you have?
Old Jun 19, 2012 | 02:34 PM
monzaz's Avatar
12 bolt cover or 10 bolt cover?
If your car is /was a 455 car it will be 12 bolt cover with 12 bolt ring and it is a FULL SIZE OLDS 12 bolt 9.3 rear (parts are NOT AVAILABLE from the aftermarket BUT I do have a complete 2.93 posi here for sale)
If your cover is 10 bolts and looks like a 1/2 ton chevy or GMC truck rear center section you have a 10 bolt 8.5 and you can buy MANY parts for this rear differential
Last you might have a 10 bolt cover 12 bolt gut PONTIAC full size car rear it was for intermediate (v8 but not high horse) powered Full size cars... There are 3.55 gears for sale in the aftermarket and the posi units are a bit easier to find than the 12 bolt olds units and gears. Have these posi units and gears too.
Pictures are below-
Old Jul 5, 2012 | 07:43 AM
7198Coupe's Avatar
I have the 12 bolt patten and it is 455 full size
Old Jul 5, 2012 | 07:56 AM
copper128's Avatar
Lt. Buzzkill (ret.)
Call Jim on the 2.93 posi. It's probably the best gear you'll find for that rear without a very long search.
Old Jul 8, 2012 | 01:23 PM
monzaz's Avatar
2.93 posi
yES THESE ARE HAD TO FIND for sure. I have only seen 3.08 and heard 3.23 better. They might have a 3.42 BUT I have not seen or heard one found yet in the 12 bolt FULL SIZE olds rear.
BUICK 65-70 YES...
Steeb75
May 20, 2012 10:43 PM
Steeb75
May 19, 2012 10:58 AM
monzaz
Mar 22, 2012 07:20 PM
oldzy
Drivetrain/Differentials
15
Aug 27, 2010 05:27 AM
Allan R
Jun 5, 2009 12:05 PM
