65-70 Big Car Rear Ends
Old Aug 15, 2014 | 03:40 PM
cfair's Avatar
Just getting curious about finding parts to swap my 66 big cars over to 3.23 rear gears which leads me to a couple of questions:
1) will the gearsets (ring & pinion) from Cutlasses / A bodies swap into big car rear ends?
2) Does anyone know what the stock ring gear bolt count was, and what the stock rear cover bolt count was?
3) Assuming my cars are stock, am I right in thinking they are 28 spline axles?
I realize I need to check all this before pulling the trigger on parts, but would like to know what I'm looking for...
Thanks in advance
cf
Old Aug 15, 2014 | 05:01 PM
Oldsmaniac's Avatar
I am no rear expert but the 65 and 66 Full size Olds mostly used the Pontiac 10 bolt cover rear. Nothing interchanges to the Cutlass rears. In 67 -70 these cars had the 12 bolt cover Oldsmobile rear. Again I dont think anythjing interchanges to the A body differentials.
Old Aug 15, 2014 | 10:28 PM
monzaz's Avatar
Full Size Olds rears
Thanks in advance
cf
1.) I assume you have the PONTIAC 10 bolt cover with 12 bolt ring in your Olds? As Olds really did not have a rear until 1967 late which had a 12 bolt cover and 12 bolt ring gear.
So assuming you have the FULL SIZE PONTIAC which LOOKS like the GTO A-body rear...IS NOTHING at all like the full size car rear. Period. NOTHING interchanges there.
2.) Stock 3.23 ring gear count is 13 on the pinion and 42 on the ring.
10 bolt cover for the early Olds full size which really was a PONTIAC catalina rear. *(reference picture attached)
3.) Full size cars in the 1965-1970 early Pontiac and Olds were all 31 spline
NON were 28 spline that was A-body cars (GTO Tempest Lemans Cutlass 442 etc) Cutlass 8.2 cover picture for reference. CLOSE but when you put them side by side TOTALLY different in depth and size. reference attached picture
Old Aug 15, 2014 | 10:32 PM
monzaz's Avatar
3.23 full size gears
Well I can tell you it will not be an easy task. 3.08 3.23 3.42 ratios are hard to find.
I had 2 sets of 4.33 gears about a year ago NOW that was a find indeed...
I have never had a 3.73 3.90 in hand ever.
A few 3.23 two hand fulls of 3.08 and I do have one 3.42 set right now along with a set of 3.08 Just received them 3 days ago...Nice garage find.
Jim
JD
Old Aug 15, 2014 | 10:35 PM
cfair's Avatar
So, net thus far is
1) A body stuff doesn't swap. Makes sense since the loads were different
2) I may have a "P" type rear under my cars or a "B", or an "O" since they used all 3 in '66.
Many thanks for your contributions
Cf
Old Aug 16, 2014 | 06:53 AM
jcdynamic88's Avatar
3:23 b body rear
according to my owner's manual and a sales brochure for 66 the dynamic 88 ,delta 88 and starfire came standard with 3:23 . I've never actually checked my 66 dynamic ratio. if this is true I wouldn't think that ratio would be that hard to find
idaholc
Drivetrain/Differentials
Nov 15, 2020 07:52 PM
gearheads78
Aug 23, 2009 08:26 AM
scrappie
Jul 21, 2009 01:29 PM
J-(Chicago)
Dec 11, 2007 07:08 PM
Olds64
Sep 25, 2007 08:19 PM
