63 Dynamic 88 Wheel help
Old Jul 19, 2008 | 09:17 AM
Old 88 Dynamic's Avatar
I need to get new wheel cylinders for my car can anyone help me out?
Old Jul 19, 2008 | 11:48 AM
dynamic88's Avatar
have you checked your local auto parts store. I was able to get mine from there for a 65 olds dynamic 88. other wise check with USA Parts, Fusicks, try YearOne. They deal in mostly cutlass stuff, but I have found that gm pretty much used all the same stuff when it came to mechanics end of things. USA Parts shows they have them, but they are pretty expensive. But most stuff there is over priced. I would check your local parts store first. i would bet they have them or can order them. chris
Old Jul 19, 2008 | 04:20 PM
rocketraider's Avatar
Oldsdruid
1959-67 big cars use the same wheel cylinders, both front and rear.
OE part #s:
Front wheel cylinders, group 4.665: LH 5465046, RH 5465047
Rears: group 4.665, LH 5465038, RH 5465039
Whatever crosses to these applications will work on your car.
Old Sep 16, 2008 | 10:55 AM
Kaline's Avatar
My local independent auto parts store (Joe's Auto Parts in Royal Oak, Michigan, which is affiliated with the Auto Value distribution network) are able to get brake cylinders old Oldsmobiles. RockAuto.com lists some of these as well. Most chain stores do not carry old Oldsmobile brake parts.
Check with a local auto parts store or NAPA. Otherwise, you can send your wheel cylinders out to White Post Restoration to have them rebuilt with stainless steel internals (http://www.whitepost.com/). Best of luck.
Old Sep 17, 2008 | 09:04 PM
Run to Rund's Avatar
try kanter.com also
absolutrj
Oct 7, 2012 07:38 PM
INTRUDER
Oct 6, 2012 08:50 AM
Captain_Fish
18
Sep 6, 2010 10:09 AM
Yllwbnna
Cars Wanted
Nov 13, 2006 09:50 AM
