400 TRANS.
Old Feb 22, 2008 | 06:56 AM
ROCKET JO's Avatar
400 TRANS.
Did 73 Oldsmobile Cutlass's come with 400 turbo trans.?? I saw most come thru with a 350 turbo's, was this a option?? I can't remeber seeing one . thanks Joe
Old Feb 22, 2008 | 10:25 AM
yogi442's Avatar
I know that my 76 came stock with one but was told that was due to coming from the factory with a tow package. It also came stock with 15 inch rims as opposed to 14's. But this was I think an option but Joe P may know for sure.
Old Feb 22, 2008 | 11:00 AM
The 455 was available through 1976 and the only automatic offered behind that engine was the TH400, so yes, the TH400 was available through 1976 at least.
Old Feb 22, 2008 | 02:48 PM
yogi442's Avatar
Joe, in my case it was as stock 350 motor with TH400.
ROCKET JO, are your referring to a 350 or 455?
Old Feb 23, 2008 | 02:47 AM
88 coupe's Avatar
Junior Member
in my case it was as stock 350 motor with TH400 ........
Anyone who wanted a 400 behind a 350, could have easily ordered it. The salesman would have the checked the proper box on the order form, and added the extra charge to the total bill.
Why anyone would, is a topic for a different thread.
Norm
Old Feb 23, 2008 | 07:10 AM
I never said it wasn't available with the 350. I said it was the only automatic offered behind the 455.
Be careful, however, to not confuse the TH375 with the TH400. The TH375 was a lower-strength version of the TH400 and was usually used behind small blocks. As an example, I had a 68 Vista that came from the factory with a 350 and TH375. It looks like a TH400 externally, but is not as strong. Note that in 68 the TH350 was not yet available and lesser small blocks got the Junkaway two-speed (aka the ST300). The beefier TH375 was used in the heavier Vista and the 350-powered 88s.
chrisneu68olds
Dec 30, 2011 10:17 AM
dgreen
Nov 6, 2011 09:40 AM
Gearhead442
Jan 27, 2011 03:03 AM
sbFALL63
Jan 23, 2011 09:01 AM
sbFALL63
May 28, 2010 05:45 AM
