1964 Ninety Eight Rear end
Old Oct 10, 2014 | 11:30 AM
Wedgewood Rod Shop's Avatar
Can someone offer detail on the rear end in a 1964 Oldsmobile Ninety Eight Coupe Holiday? I am looking to change out the differential to a posi with a different ring & pinion.
Old Oct 10, 2014 | 01:05 PM
The stock rear would be a 1957-64 Olds/Pontiac rear with the drop-out center section, similar to a Ford 9".
Old Oct 14, 2014 | 07:48 PM
marsman's Avatar
57-64 p/o 9.3
hey wedgewood, check out fabcraft serious stuff;spools, posi's, gearsets
Old Nov 17, 2014 | 04:53 AM
monzaz's Avatar
9.3 Olds Pontiac gasser rear
This is a VERY strong third member -
They used these in the Gassers and Top Fuel dragster of the day... It was considered the best rear end of the time. Stronger than anything
1.875 pinion shaft huge bearing caps strong posi etc.
I have posi units and gears and rebuild kits BUT everything is very expensive. The older the rear gets the more money it is to restore. Jim
J D
330 990 8155
Old Jan 20, 2015 | 08:20 AM
9.3 Rearend
J D
330 990 8155
Do you have a posi unit and either a 3:90 or 4:10 ratio Ring & Pinion? If so, what would the cost be?
Thanks!
Lucas
DaCrup
Jul 29, 2015 11:32 AM
Oldsrick
Cars Wanted
Jun 3, 2013 01:29 PM
Jura
Ninety-Eight
Aug 25, 2010 08:54 AM
Jura
Sep 28, 2009 09:32 AM
