1949-52 Olds rear ends. Looking for 3.23
Old April 13th, 2009, 01:22 PM
idaholc's Avatar
I have a 1949 Olds Coupe with a built 425 Olds and a 700R. The Stock '49 rear end has 3.64 gears. At 75mph I am turning 2378 rpm. I would like to install 3.23 gears for 2110 rpm at 75mph and better MPG. Is there a point of diminishing returns on rear end gearing and cruising fuel efficiency? Does anyone have a set of 3.23's?
idaholc is offline
Old April 13th, 2009, 01:37 PM
idaholc's Avatar
Matching ring and pinion
The 3.64 gears I have have a 40 tooth ring gear and 11 tooth pinion, thus 3.64 ratio. The 3.23 gears I am looking for has 42 tooth ring gear and 13 tooth pinion, thus 3.23 ration.
Question, could I mate a 13 tooth pinion gear to the existing 40 tooth ring gear and get a 3.08?
idaholc is offline
Old April 14th, 2009, 08:10 AM
monzaz's Avatar
rear diff 1949-1950
I have a 3.42 complete center section...actually the whole rear if you need axles and or backing plates you might want to get extras if you need.
I can send pictures of the rear if you are interested...yes, I can and will ship to you also.
I think about 65-70 pounds fed ex ground would be- about 45-50 dollars to ship
monzaz is offline
Old April 14th, 2009, 10:13 AM
idaholc's Avatar
I am shooting or at least a 3.23 if I am going to the trouble of changing. they were only found in 1949 88's. Thanks anyway.
idaholc is offline
Old April 14th, 2009, 10:17 AM
ate glue as a child
jaysun's Avatar
Gleason hypoid generator? does that take 1.21 gigawatts to operate?
sorry i'll be quiet now.
Jason
jaysun is offline
Old April 15th, 2009, 07:44 AM
ate glue as a child
jaysun's Avatar
There always something to learn.thanks CW
jaysun is offline
Old April 16th, 2009, 09:37 AM
idaholc's Avatar
3.23 found
thanks for your help. I found a 3.23 gear set locally, so no shipping costs. Now I will soon have a set of 3.64's available.
idaholc is offline
Old April 16th, 2009, 09:39 AM
idaholc's Avatar
1949 50 Olds Gear ratio chart
By the way you guys, I have acquired a list of all 1949 and 1950 Olds rear end
ratios and what models they came in, in case anyone is interested. I could pass it along.
idaholc is offline
Old October 16th, 2009, 06:10 PM
mo381's Avatar
I would be interested in learning about the rear end in my 51 Super 88. Any info would be helpful.
mo381 is offline
Old November 9th, 2014, 08:08 PM
monzaz's Avatar
GEAR swap
Originally Posted by idaholc
the 3.64 gears i have have a 40 tooth ring gear and 11 tooth pinion, thus 3.64 ratio. The 3.23 gears i am looking for has 42 tooth ring gear and 13 tooth pinion, thus 3.23 ration.
Question, could i mate a 13 tooth pinion gear to the existing 40 tooth ring gear and get a 3.08?
you can not mix and match ring and pinion gears! They are match sets.... Even mixing 3.23 ring and opinion with 3.23 ring and pinion gears might have issues with noise etc.
monzaz is offline
Old November 9th, 2014, 11:51 PM
Ozzie's Avatar
Post
If Hollander is accurate, the choices for late '49-'52 on the 8 cylinder with Hydramatic were 39-10, 40-11, 41-12, 42-13, and 40-13. Your choice might depend a bit on the type of terrain you drive and the loads you move. I have a '55 which I drive mostly on flat terrain. It has the 40-13 and can pull a trailer with boat and the A/C running without any distress.
Ozzie is offline
Old October 14th, 2016, 05:46 PM
A Close Cousin
Jimmy Davis's Avatar
Sent you a message ... wondering if you're still looking for a gear ratio change!
Jimmy Davis is offline
Old November 15th, 2020, 08:35 AM
Mark Davis's Avatar
50 olds 88 rear dif ratio
I have a stock 50 olds 88 fastback, What is the differential ratio?. Im trying to figure out what speedo gear to put in the 700R4 that Ross Racing sent me.
Mark Davis is offline
Old November 15th, 2020, 07:52 PM
Tedd Thompson's Avatar
I myself would not build a rear end from a early 50's Oldsmobile that had a engine that produced somewhere around 400 HP. besides being a peg leg doubtful it would stand up to the HP should you ever hook up.... Just a thought....Tedd
Tedd Thompson is offline
morepwr
January 1st, 2012 11:10 AM
gearheads78
August 23rd, 2009 08:26 AM
idaholc
Drivetrain/Differentials
June 1st, 2009 09:22 PM
brayden01
January 15th, 2007 03:42 PM
brayden01
January 15th, 2007 01:57 PM
Quick Reply: 1949-52 Olds rear ends. Looking for 3.23
